ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Try downloading from the memory card. You will have to purchase a card reader, usually less than $20. It will save the batteries, too, since the reader is powered by the computer.
Make sure the batteries have a good charge. The camera powers the download not the pc.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Page 66 of the user manual - see link below details how to do the copy -
Copy To Card
1. Select the [Copy To Card] menu tab by pressing the Up / Down button. And then press the Right button.
2. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- [No] : Cancels "Copy to Card".
- [Yes] : All images, movie clips and voice recording files saved in the internal memory are copied to the memory card after the [Processing!]message is displayed. After copying has been completed, the screen will return to play mode.
Try turning off the camera. While it's off remove and reinsert the memory card. If the same message appears, you should re-format the memory card. CAUTION: Formatting the memory card will delete anything on it. Copy the files off of it before formatting.
Here is your manual: http://support.casio.com/pdf/001/EXZ60_e.pdf
This error message means that there is not enough space in the location you are copying to (internal memory or card). Delete pictures from the location you are copying to, or turn off the camera and insert a new memory card.
This error message indicates that there is no more space on the memory card in the camera.
To resolve this problem, do one of the following:
Turn off the camera and insert a new memory card.
Transfer or delete pictures from the memory card.
Change the storage location to use the internal memory.
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
