Behringer Active 150Watt PAMonitor Speaker System Logo
A
Anonymous Posted on Jun 24, 2011
On stage live...I want to use the B205D as a personal monitor...the band uses a Yamaha EMX512SC 8 powered mixer on stage...What would be the correct connections to hear only my vocals in the B205D monitor but still be heard in the Mains.
Fred Yearian
Level 3:
  • Behringer Master 5,603 Answers
  • Posted on Jun 25, 2011
Fred Yearian
Behringer Master
Level 3:
Answers
5603
Questions
Helped
2248613
Points
16162
Oh my... the EMX512SC does NOT have any "sub busses" there fore there is no way to just hear YOUR vocals where there are other vocal present. The way to connect this is to run YOUR mic into the B205D and then run the line output that is intended to run to other B205D's from the B205D into a channel of the EMX512SC.
I HAVE NOT RECEAVE IT YET I'M ASKING WHY HAVE I NOT GOT IT YET BEEN MORE THEN 2 MOUTH
Fixya does not sell anything. You need to contact whoever sold you the item directly to ask them about when/if it was shipped.
Why does mixer cracle and shut off when it gets hot?
Because the power supply is breaking down and needs to be replaced.
Shud i get an external equaliser? i'm using MG166CX 16-Channel Mixer as the main mixer.
An external equalizer will not help this at all. The problem is likely within the amp (feeding the main speakers), the connections from the board to the amp, or the speakers themselves. In other words, the answer would be "NO." Best of luck!
Jan 14, 2013 • Music
1helpful
Using Ipod with emx512sc
Make sure that the Player is set to iPod mode and not AUX.
Monitors not working on Yamaha EMX512SC, worked once added a keyboard,now we can't get them to work.
Do you mean there is no sound coming from your monitors? Check whether you've accidentally diverted the main-mix signal from main-out (or whatever you have your monitors plugged into). Can you get a headphone mix?Also, dumb question, check that nothing is soloed!
Why is the yamaha emx512sc so light weight
Because it is solid state for one.
It is also a Class D type amplifier, so the 500 watts is only a a peak rating and not very accurate, it is not an RMS rating, there is a big difference.
Class D amps chop up the music stream so it is not a continuous signal like analog signals are. It has a generalized block diagram similar to a power inverter or an AM transmitter. You ear is not likely going to notice the difference.
I have to turn the master switch all the way on to hear the music and then my microphones are too loud
Watch videos on YouTube about proper setup of a mixer/amplifier. Proper level setting at the different stages of the mixer is important to balance. You don't give us a clue as to what music you are talking about... if it is from a device plugged into the tape inputs for instance, the fault is your source is NOT providing adequate line-level to those jacks and you are trying to compensate with the master level. The master level should probably be around60% up in normal operation.
I had major static sounds from my yamaha stagepas 500. I plugged in an acoustic guitar into the mixer while running a keyboard and 2 vocal mics. I started getting crackling sounds. I changed the patch...
Chances are there is nothing wrong with the mixer. IF you accidentally turned on Phantom power, that would cause the problem. Phantom is ONLY used with condenser mics and a few DI boxes. Turning it on can create noise unless balanced lines are used everywhere.
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
