HI - A RED LIGHT ON ITS OWN MEANS THERE IS A COMM PROBLEM BETWEEN THE DISPLAY & CONTROL MODULES. THE FAULTY UNIT WOULD BE THE DISPLAY, THIS IS A TOUGH ONE BECAUSE THIS DOES NOT ALWAYS WORK, OFTEN THE ACTUAL PROBLEM IS THE CONTROL MODULE ITSELF.
I WOULD BE INCLINED TO REPLACE THE CONTROL MODULE INSTEAD..
CHEERS
SOURCE: F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
