Check if there's a power and try to make a call or check any signs that the phone is responding (like opening tones)
If its still working,DIY method here :
1. remove the front cover by flipping it up,start from the side edges.
2. there are 4 screw on each corner and 2 screw in the middle, unscrew it using a T6 precision screw driver or you can use any that fits the screw.
3.lift up the entire board then remove the metal shield that protects the lcd. check the lcd if its well fitted as well as clean both terminals.
4. then put it back as it fits and assemble your phone.
If this method doesn't work? need to replace LCD,parts are available in any mobile service shop s near you.
But if the phone just in white screen mode,might need to program the phone. or if the phone is totally dead,check or try another battery first if this will power on.
Good luck....
After Fell down there may be loss connection with Display & display connector if your a Technician then Refit the display and see it may get solved. if it dos not solve Please Replace the display it'll solve.
If your not a Technicianthen please Visit your nearest Nokia Service Center (Nokia Care) or Visit any Mobile Repair center they will do this.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up & Testimonials //
