I have an LG golden eye tv 61cm which is nearly 11 yrs old, after the tv is on for 10 minutes it turns itself off and i can not turn it back on even after 30 - 40 min later, what is wrong?
Have the speaker and wires tested, follow the wires back and see if where they plug into the circuit board the plug came out or the board itself got cracked, a visual inspection should be able to find a crack etc.
The problem of your tv is the heater, try to open the back cover of your tv, but be sure to unplug it first, then if you do that try to plug in the tv, then switch it on but be very careful, then try to observed if their is a light that is glowing in the picture tube if their is no light your heater is defective try to check the resistor that is connected in the heater you will see in the pcb it has a marking of H it is connected in the picture tube be careful.
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
