If you by pass the filter does the water flow? I suspect your water valve may have gone bad. Have you tested that by any chance?
Also make sure the filter is in correctly and no loose lines and is locked in tightly. I would do two things: make sure the water reservoir in the refrigerator (behind the bottom drawer) is not frozen and check if 120 VAC coming to the water valve solenoid while the water dispenser calls for water.
Here is a link to a page that describes how to test the water valves.
www.appliance411.com/faq/test-water-valve.shtml
water if flowing fine, just no ice
