SOURCE: lumix pictures blurry
I would suggest that the image stabilizer might not be working right. Could you upload a photo to Flickr or other location where I could look at the EXIF, or list it here. I would like to see what the camera is writing to the image as the settings when the photo was taken.
Does it make a difference when the image stabilizer is on or off?
SOURCE: help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
SOURCE: panasonic lumix dmc-lz7 lens barrel doesn't move
Hi Sarah I am Vortash it shouldnt need to be a new camera a good clean out by an engineer should cure the problem provided you havent tried to force the lens back in if it was out , he will clean it with white spirit or alchahol and re set the lens mechanism and it shuold be fine .. but get an estimate first as the economics may be in favour of a new camera if it would cost too much .. in the uk here we charge approx $25 for that but it may be more over the pond .. regards Vortash
SOURCE: have Panasonic Lumix DMC-TZ5. get message turn camera off
Did you drop the camera on the lens?
You have to replace the barrel (cost around 175,00 euro)
try to find a cheap second hand camera en replace the lens unit...
SOURCE: Hi, I have a panasonic Lumix, DMC-FS5 digital
I had this same problem. I have just pulled the lense (not with any major strength) when it was fully extended. This seems to have solved it for me!!
Dont worry, think I solved it! Had he camera set to burst mode- flash settings seem to work when burst mode is switched off...
