ASUS (wl500g) Wireless Router Logo
Posted on Jun 26, 2011
I need to change my password - ASUS (wl500g) Wireless Router
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
78
Points
Reset it ! Just 10 seconds reset button..........Press !
1helpful
2answers
I want to change my Netflix password
  1. Login to Netflix and ensure the primary account holder's name is selected in the upper-right corner of the screen. ...
  2. Mouse over your name in the upper-right corner, then choose "Your Account".
  3. Select the "Change password" link.
  4. Type your "Current Password", "New Password", then "Confirm New Password".
I want to change my yahoo password?
Yahoo users need support to change or to reset Yahoo password then just make a call on yahoo password recovery number 1-888-587-9269 anytime. Users may lose their Yahoo password or they need to change their Yahoo password due to any kind of security reasons so users may call on Yahoo password reset number 1-888-587-9269 and technicians are there to help you and describe each and every steps to change or reset Yahoo password.
Steps to reset Yahoo password
  1. Users may need to go their account and login
  2. Then there is an option of change password or forgot password so users need to click on that
  3. Now they need to change their password as the space provided
  4. Then there is verification mail sent to the verified email so, users need to click on that
  5. Now the password has changed again users need to login to their account with a new password
Still, have an issue than just make a call on Yahoo customer service number 1-888-587-9269 anytime. Customers may also go through Yahoo customer service number 1-888-587-9269 if they need any other guidance to fix an issue related to Yahoo anytime.
So, users may call on Toll-free number 1-888-587-9269 anytime and get support to sort issues related to Yahoo anytime. Click here to know more: https://www.hubcustomersupport.com/yahoo-password-reset-number
hi William.
you have not said what password you want to change but see if this is it.
How do I change my password on Google? Change your password
  1. Sign in to My Account.
  2. Under "Sign-in & security," select Signing in to Google.
  3. Choose Password. If you see a prompt to sign in again, sign in.
  4. Enter your new password, then select Change Password.
Change or reset your password - Google Account Help - Google Support
https://support.google.com/accounts/answer/41078?hl=en Search for: How do I change my password on Google?
if not go to this link should help you out.
how to change my password Google Search
2answers
Hi, How to change Cisco IP Phone voicemail password on router. Thank you
on the CLI you need to change the username and password on the ephone for that phone. Then you need to session into the CUE module and change the password there as well. do a show run and find the username and password that you need to change and then do config t and change the password. The user can also do this on the phone if they know the previous password.
3answers
Need to reset my password
Change your Google Account password To change your Google Account password, go to the change your password page.
Or you can follow the steps listed below:
  1. Sign in to your Google account. If you've forgotten your password, type your username on the trouble signing in page to reset your password.
  2. Go to the Google Accounts security tab.
  3. In the Password box, click Change password.
Remember that changing your Google Account password changes it for all Google products you use, like Gmail and YouTube, so be sure to use your new password the next time you sign in.
Aug 19, 2014 • gmail.com
Changes password
If you need to change a password then there may be a option to change a password or forgot password. Click on one of those. If you choose change a password then you need to remember your old password if not you can go to forgot password and follow the instructions given. Usually they send a rest link or some activation code will be send to reset or change the password.
Thanks
2helpful
I have the first firefly phone from att&t then cincular i am needing to reset password and don't remember the code to do that.
For the Original Firefly Phone:
The default PIN is: 1 2 3 4.
For the glowPhone:
The default Password is: 0 0 0 0
When you first set up your password, you will be able to change from the 0 0 0 0 and enter your own.
If you should happen to forget what password you entered, you can enter the bypass password: 5 6 7 8 and this will then allow you to go into Parental Controls and change your password:
- Scroll to and select Permissions
- Scroll to and select Change Password
You will be prompted to enter a new password, then reaffirm it. You will get a confirmation when the password is successfully changed.
For the flyPhone:
The default password is: 1 2 3 4
When you first set up your password, you will be able to change from the 1 2 3 4 and enter you own.
If you should happen to forget what password you entered, you will need to follow these steps:
- Turn on your flyPhone
- From the Main Firefly Screen, you will need to type in the following (once you start typing, the screen will change): #20070330#
This will restore your flyPhone back to the default settings, so you can now go back in and reset your password.
or try this:
How can I change my phone's Password/PIN? For the Original Firefly Phone:
- Press and hold the green SEND button until you see ENTER PIN. Press Enter.
- Enter your PIN Number by scrolling though and accepting the four numbers you choose. (The default PIN is 1 2 3 4).
- Scroll to DONE and Press OK.
- If your PIN numbers are accepted, the display will say Change PIN.
- Press OK to let Firefly know that you do want to change that PIN.
When the display panel says SAVED, your new PIN is loaded.
For the glowPhone:
For the flyPhone:
Hope this helped.
Source: http://www.fireflymobile.com/
1helpful
CHANGE PASSWORD/ETHERNET ROUTER/WINDOWS VISTA
to make it clear..
change password meaning you need to update your router's password?
SOLUTION: access router's interface and enter correct password information
OR
change password meaning reset your password for your router?
SOLUTION: call router provider/manufacturer ISP to have router's password reset..
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
