Question about Quinny Buzz Jogger
My quinny buzz four which i bought off ebay a couple of weeks ago has today started collapsing when i go up kerbs mostly one side. Its fine going up and down (the hydrolics) and doesnt happen all the time but its quite scary ive been in touch with the person i bought it off but shes stating it was fine when i sent it. Im wondering if you know what could cause this and if i can get it repaired. thanks
  • Quinny Master
  • 1,637 Answers
Hi Carmel
Please contact us directly to discuss
Dorel UK Customer Service
Posted on Nov 16, 2014
6ya staff
SOURCE:
Anonymous
SOURCE: Quinny buzz
go to www.quinny.com/media/producthandleidingen/Quinny/01638_inst_ES_083107.pdf
Posted on Jan 10, 2008
Anonymous
SOURCE: quinny buzz shopping basket
1. take off the front wheels by squeezing the two buttons on the aluminium tube just up from the wheels.
2. slide the metal clip up the groove in the tube.
3.use the two velcro straps around the tubes that support the rear wheels to hold up the rear of the basket.
4.re fit the front wheels and make sure the buttons snap into the holes in the tube
Posted on Aug 15, 2008
bunnydawg
Roberta Smith
  • 5158 Answers
SOURCE: collapsing the quinny buzz
you should be able to find the manual here
http://www.quinny.com/quinny/productdetail.aspx?id=3
Robert
Please rate the solution
Posted on Sep 08, 2008
Anonymous
SOURCE: quinny buzz replacement seat cushion or cover
According the customer support at Dorel, there will be new seat liners/hoods for sale soon.
Posted on Oct 23, 2008
Anonymous
SOURCE: Turning Quinny Buzz 3 into buzz 4
I bought it and its great - much easier to push
Posted on Mar 14, 2009
Bought quinny buzz 3 second hand, the frame has dropped on one side, how do i fix it?
Good Evening
Unfortunately there is no quick fix for this; It sounds as though one of the knuckles has broken, causing a one sided chassis collapse.
What country are you in?
May 18, 2011 | Quinny Buzz Three Wheel Stroller
Quinny buzz stroller keeps collapsing when in use
Hi if you bought it within 60 days you can open up a claim on ebay & get a full refund. i sell them in perfect condition & would never sell 1 that is faulty. The only other option is if you are putting bags on the handle this will make if fold up on itself. contact me @ marie-lowe@hotmail.co.uk
May 10, 2010 | Quinny Buzz Three Wheel Stroller
Is it possible to convert the Buzz 3 front wheel to an inflatable tyre? If it is I'd like to do it - it will overcome the problems of pushing on rough terrain!
Quinny do an All-Terrain front wheel that replaces the front wheels on a Buzz 3. It's basically two new front wheels that are slightly bigger and pnuematic. Worked a treat on a recent holiday to Brixham where we took our Buzz onto the un-surfaced coast path. We got ours from www.babycare.nl a dutch site that sells Quinny Spares it costs Eur62.50.
Jan 16, 2010 | Quinny Buzz Three Wheel Stroller
My quinny buzz 3 chassis sometimes starts to partly collaspe when in use, especially when weight put on it, i.e when going up kerbs. Any suggestions to mend? I bought it second hand but it is only 18...
the bolts on the side where the lower section meets the arm need to be checked and tightened as these lossen i have had this happen my self very scary x
i found that every time i opened my pram it would not be fully locked together so i put my foot on the bottom bar and pulled the bar up untill it clicked into place and no longer had issues with it trying to fold itself while in use hope this helps x
Dec 10, 2009 | Quinny Buzz Jogger
Hi my quinny buzz seems to be collapsing when the baby is in the pram the "round bit" at the front is not catching therefore it is collapsing hope this makes sense many thanks jacalyn
try the bolts at the sides of the pram as they can come loose if it is the black joints on the side it is likely to be broken but you can get a replacement chassis on ebay for around £50 hope this helps x
Nov 29, 2009 | Quinny Buzz Jogger
My quinny buzz is collapsing , can somebody tell me where can i buy a new frame maybe and spare wheels
alot of people on ebay sell spare frames and wheels. I had similar problem when mine kept collapsing. I had to open it then pull the part that slides up the chassis stem up a bit further till the 2 black plastic parts clicked into place.
Jul 03, 2009 | Quinny Buzz Three Wheel Stroller
Main frame and worn wheels of the quinny buzz
This happened to my wife the other day, I found that the main pivot bolt had pulled through the plastic pivot/collapse assembly. This part is rivoted to the frame so without drilling it out and replacing with an ugly nut and bolt you will have to source a new frame. I got mine from Ebay, I found someone selling lots of quinny buzz bits and asked if he still has the frame he said yes but the handle bar no longer extends (Hence im on here looking how to swap the two), Problem solved!
I also found out from Quinny that the Buzz has a 2 year manufacturers warranty, where Motercare insisted it was 1 year, so dont let them fob you off.
Hope this helps
Chris.
May 18, 2009 | Quinny Buzz Jogger
Quinny buzz
Hi if you have not got bags on the handle then yes it needs replacing if it is less than 2 yrs old you can call dorel to fix it, also I have heard that if you send the frame to them & £30. for a service the will fix it. Let me know if this works.
Dec 19, 2008 | Quinny Buzz Jogger
Hi I got a nearly new frame off ebay for a bargain! There are loads of spare parts to be had on there.
Aug 03, 2008 | Quinny Buzz 3 Sulphur Jogger
Quinny Buzz Jogger Logo
135 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
doobuster
Tom Chichester
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
