Question about Salton Microwave Ovens
To make Lemonade, how much Lemons/Water/Sugar do you use?
  • Salton Master
  • 3,740 Answers
6 or 7 lemons
1 cup sugar
6 cups cold water.
You can add more sugar to taste after stirring everything together.
Mix
taste...
sweeten if you so desire.
Posted on Jun 26, 2011
  • Kelly
    Kelly Jun 28, 2011
    How was the Lemonaide?
    Kelly
How to get baked on br sugar off the glasstop we made hot pepper butter, it has brown sugar white vinegar, salt and mustard in it spilled over and we have a mess, we have used warm water,and a fine...
Oven cleaner is made just for this type of mess. Use with caution since it contains lye. Put a towel over your mouth and nose when spraying, wear rubber gloves, and avoid contact with painted surfaces. Leave on for about 20 minutes, wipe off, then wipe with a damp sponge.
Sep 11, 2011 | Whirlpool Microwave Ovens
My Kenwood does not cream butter and sugar to 'light and creamy' mixture. I am using the standard large bowl that came with the mixer and have tried both the wire whisk and Kbeater. The mixture...
Hi Julie
It could be that you are using too much sugar, therefore making a more coarse mixture. Beat your butter first, then add the sugar until your mix is as you want it. The Beater would be the proper tool for this. The whisk is for meringue or whipped cream type mixes.
I hope this helps you to some degree
Joe
Sep 07, 2011 | Microwave Ovens
How to set temperature in Samsung microwave. 160 c means ? watts.
They're totally non-interchangeable as they're two totally different ways of cooking.
There is no correlation at all between a temperature setting used by electric and fan ovens and the microwave power level, there's not even a rule of thumb. For microwave cooking, the fat, sugar and water content of any given food item as well as the mass and shape are what determine cooking times and microwave power levels, and not all foods can be safely microwaved as high fat/sugar content foods may catch fire.
Jul 06, 2011 | Samsung MW4699S Microwave Oven
Pie boiled over and sugar is really burnt on
Most microwaves have trays that can be removed and cleaned. Make sure you don't use it again before cleaning it. try soaking it in water over night or putting wet towel on it. Then scraping it off tomorrow while it's still damp
Mar 15, 2011 | Microwave Ovens
My DeLonghi Magnifica S ECAM23210 coffee machine is leaking water from the back.
I received the exact same machine for Christmas yesterday and had the exact same problem! I took it back to Williams Sonoma today and exchanged it for another one and I just started it up and have the SAME problem! Water comes out the bottom onto the counter - never even makes it up through the machine. This must be a batch of lemons - I guess I'll call Delonghi tomorrow.
Dec 25, 2010 | DeLonghi Microwave Ovens
In what order do I add the ingredients for white bread?
Flour, salt, (nuts/seeds etc), sugar, yeast water (and milk for preservative).
Enjoy.
Dec 24, 2010 | Microwave Ovens
Food left in the oven has left a smell even after thorough cleaning.what action should i take
Have you tried putting a microwaveable bowl with a mixture of water ,vinegar and some slices of lemons or oranges in your micro for about 2 minutes. It should help eliminate the bad odors and leave your microwave smelling freah and clean.
Nov 10, 2010 | Panasonic NN-H965 Microwave Oven
I have an Oster Bread maker model # 4811 and the
If it's heating at all, the element is probably good. If it is cooked partway, but not fully, that could be because it isn't rising. Make sure the dough is the right consistency before baking, as a different flour could have a different moisture content, thus requiring a different amount of water. Make sure there is sugar in the dough for the yeast to "eat" or it will not rise. If all else fails, try other yeast. Your can also test the yeast by proofing it. Put a teaspoon of the yeast in a cup of warm water with a teaspoon of sugar. It should foam and bubble in 5 minutes or so. You can find more detailed directions on testing the yeast by searching "proofing yeast" on a search engine. Good luck.
Jan 24, 2010 | Microwave Ovens
A chemical or burning odor
try cycling a solution of water and lemon for 1 to 2 minutes. lemons is a good deodorizer.
Oct 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool mh1141xmq
Unplug the thing, open it up, and carefully take off the pad button controls and anything else with wrong behavior, and wash those things out with dishsoap and deionized water.  It seems like a pad switch has saltwater or sugar in it, or crumbs pressing on it.  The door and main switch often need cleaning out also, though compressed air or cotton swabs (no excess water) will be fine.  Then put it back together, plug it in, and try it.
Jun 29, 2008 | Whirlpool MH1141XM Microwave Oven
Microwave Ovens Logo
78 people viewed this question
Top Salton Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Ruth summersides
Are you a Salton Microwave Oven Expert? Answer questions, earn points and help others
