Hi guys,
This error occurs when paper sensor in ADF = Automatic Document Feeder detects some paper inside paper path. Firs, open ADF access cover and check if some broken paper present inside paper path. If no broken paper found in paper path means paper sensor is faulty and you need got new ADF replacement. Thanks
Source:
MX340 Series Service Manual
Instructions to change the machine back to its default settings.
Make sure that the machine is turned on.
Press the Menu button repeatedly until Device settings appears.
Use the button to select Reset setting , then press the OK button.
