Hi
This is problem probably come when your system infected with virus or registry setting is corrupt, If you format you hard disk and try to install the new windows and Blue screen is come then, go to the BIOS and select SATA compactablty Disable. Now you don't get the blue screen error.
If my solution make you happy give me the four thumb
Cheer
It is not a hardware issue. It is easy to install Windows 7 in your laptop but if you want to install Windows XP you have change the Hard Disk type to IDE. For that you have to change settings in your BIOS. After changing to IDE you can continue your installation normally as you done earlier...
thanks & regards
Anas K A
