Quinny Buzz Jogger Logo
Posted on Jun 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to get two back wheel and acsel - Quinny Buzz Jogger
Dorel UK
Level 3:
  • Quinny Master 1,637 Answers
  • Posted on Nov 16, 2014
Dorel UK
Quinny Master
Level 3:
Answers
1637
Questions
0
Helped
453852
Points
2410
Hi Sheila
Please contact us directly to discuss -
Dorel UK Customer Service
Remove steering wheel on 85 dodge diplomat
Disconnect the negative battery terminal. Remove the horn pad on the steering wheel-Phillips head screws from the back side of wheel. Then loosen the nut on the steering wheel center. Mark the steering wheel to column shaft position, so the wheel goes back in exact same position on the shaft. You may need a steering wheel puller to get the wheel off the shaft, not always, but sometimes the wheel is on pretty tight. Do not hammer on the wheel to get it off, use a puller if needed. These pullers are at parts stores and not expensive.
When pushing my quinny the back wheel starts to come of byitself
Hi Lisa - It could be that if there is dirt and debris on the wheel axel or inside the connection it would prevent the wheel clicking in properly. Remove both back wheels and give a wash in warm soapy water then dry thoroughly before putting back into place. Does the same side wheel fall off even if you swap the back wheels over? If this is the case it would indicate a chassis problem rather than a wheel problem. If it is the same wheel that always falls off it would suggest a wheel problem. Contact customer services on 01284 413 141 Mon-Fri 8.30-4.30 or e-mail to [email protected] for further advice
2helpful
I ve broken 2 lugs off right rear wheel i removed tire wheel and brake cover tried to pull wheel with wheel puller it is not moving am i proceeding correctly or do i need a bigger hammer
why are you trying to pull the ( wheel ) . If you need to replace the 2 broken lugs then all you need to do id hammer them back thru the ( wheel ) and go get 2 new ones that match those broken ones and hammer them back in from the back side of the ( wheel )
Took chain off to remove wheel and am unable to get chain back on correctly. 2001 Magna oasis 26" 7 digit shifting speed. Unablew to locate manual...can you help?
Put the chain to the inside of the front cog wheel, beside the pedals, first but not onto it, so you have plenty of room for pulling the chain to the rear. Fit the wheel back into place and before tightening it pull down the spring loaded arm, with the small cog wheel beside the back wheel. This takes the tension off the chain and allows you to put it into place on the back wheel. Tighten up the wheel. When it's tightened fit the chain onto the top of the front cog wheel. Lift the back wheel off the ground and turn the pedals forward. The chain will click onto the front cog wheel when you have turned the pedals one complete turn.
If you need to see a picture of how it should look at the back you can see one at http://orangecounty.craigslist.org/bik/2409696114.html
May 29, 2011 • Cycling
2answers
Rear brakes sticking
need more info---did you have brakes worked on, did it happen all of a sudden???
1helpful
Won't just stay in one gear. constantly doing gear changes on its own. Hardrock. Rear set, reguardless of which front gear.
This happens when the back wheel is not aligned properly with the chain. As the wheel turns the chain is being pulled to one side causing it to slip to the next set of cogs. To solve the problem first you need to loosen the wheel by opening the 2 nuts on the axel. If the chain slips inwards towards the wheel you need to move the front part of the back wheel to the left from a view point behind the bike. If it slips outwards away from the wheel then you need to move the front of the back wheel to the right as viewed from behind the bike. When the chain and cogs of the rear wheel are lined up in a straight line the problem should be solved.
Need a spare wheel for a combination mamas and papas pram
i have a 3 wheeler fisher price buggy but the back wheel clip is nackerd where can i get new wheel
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
