Question about LG 37LC7D 37 in. LCD HDTV
My tv is not getting the signal from my direct dish.Just says no signal. I contacted direct and we tried several things via phone. They said the problem is with my tv not the dish or receiver. Nothing has been changed since the original hook-up done by direct. My tv turns on and off ok and worked fine before I went on vacation.
  • LG Master
  • 8,457 Answers
Tries tv and the dish box unplug,replug it back an hour later for the tv to do a restting itself back to the factory setting and dish box to reboot and upgraded it software.This no signal problems should be fixed,not request another dish box for the replacement,because tv have no signal input bouncing around in the tv screen it is 90%-95% are broadcasting receiver boxes for tv incomming signal cable for tv signal problems.
Posted on Jun 27, 2011
Only one satellite signal on vip722 dvr
Hi there! My name is Kimberly and I forma part of the Social Media team with DISH. I apologize for the delayed response and for the inconvenience you have experienced. It is my pleasure to assist you. At times when you are experiencing signal loss there may be lots of things that could be causing it, for example: bad weather, mis-aligned dish, lose connection, or bad receiver. You can follow this link http://www.mydish.com/support/complete-sig-loss?WT.svl=gsearch_results to help you troubleshoot the issue. If you need further assistance please feel free to contact me directly at kimberly.escobar@dish.com
Kimberly Escobar
Social Media Representative
DISH L.L.C
Apr 05, 2013 | DISH Network 301 DTV Receiver
What do I do to get my signal back on my westinghouse TV that is hooked up to dish cable
If no signal via the cable fitting try hooking set via one of the sets of jacks on the back (audio/video or component) to see if coax input or tuner is bad.
If the set works with a DVD etc hooked to one of those inputs and your cable is good--maybe a bad tuner in the set---also if using a box try hooking cable direct to set to rule out the box.
Mar 17, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
My TV randomly gets a blue screen with a no signal message. Exactly like the TV was turned on without my Dish Network box turned on. I thought the Dish box was going out so I replaced it. It still did the...
That can certainly be a frustrating issue!! Because you have already replaced the box, and you are getting the same thing, it is not a receiver issue. If you are able to temporarily get the TV to stay ona fter you turn it off and then back on, it could be a TV issue.
If your receiver and TV are plugged into a surge protector, try plugging them directly to the wall. Another cause of this issue could be your grounding for the DISH Network system, meaning that a tech may need to come out and inspect that. Feel free to send me an email if you continue to have issues!
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Jul 24, 2011 | Olevia 237T 37 in. LCD TV
You're closed captioning is all jumbled up on Seattle's KIRO TV from my DISH network. The cc works fine on all other channels. Dish says it's a network problem. Any response?
The CC is provided to DISH (and all cable/satellite companies) by the network that creates the programming. Usually, live TV (like news, sports, etc) is the most jumbled because of the time it takes someone to transpose what is being spoken as it is being spoken. If this is a network that is available OTA (via antenna), verify that the issue is not happening when you are receiving the signal from somewhere other than DISH (if you cannot receive an OTA signal, try at a buddy's house that uses another cable provider). If the problem occurs via OTA or other providers, contact KIRO to have them improve their CC service. If it only happens when viewed with DISH, contact DISH, who will then resolve the issue with KIRO (usually a lag time in signal transmission from the provider).
Feb 11, 2010 | Televison & Video
Does Uniden sell Satellite Dishes? Several years ago people were able to purchase Satellite Dishes from Radio Shack. This enabled them to get non scrambled television stations from around the world. Does...
What you are referring to is a FTA receiver. These are generally considered to be illegal and people who install them are then charged 4500.00 by direct tv because of the assumption that their signal is being stolen. Uniden no longer sells them for this reason
Apr 17, 2009 | RCA DISH Network(r) 311 Satellite System
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
Connection to Dish service
Your t.v is having only RFin , and if you connecting dish receiver , normaly their are two o/p for receiver one is RF and two is for audio out and video out. if your connecting direct RFout to t.v RF in then you have to tune the t.v in all bands. if your receiver do not having RFout facility, then you have to connect AV out to converter and then RFin of t.v. if you having a vcr, then connect AVout of dish receiver to vcr AVin and then vcr RFout to t.v again tune the t.v and pwer on the vcr.
Jun 24, 2008 | JVC Televison & Video
Direct TV
Signal issue generally refers to the satellite dish being out of alignment. If you have a single LNB, (one knob on your dish) you can reaim it with two people, on inside telling you your strength and you aiming the dish. If you have more LNB's, the easiest way is with a satellite signal meter, which can be expensive.
Apr 25, 2008 | Directv (DWO2-10024)
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
LG 37LC7D 37 in. LCD HDTV Logo
1,117 people viewed this question
Ekse
RONALD CARTER JR
