Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens Logo
Posted on Jun 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My AF-S NIKKOR 70-300 1:4.5-5.6 G lens will not focus properly. The focus keeps jumping in and out and the motor has gotten noisy. I checked all function controls to ensure nothing got knocked out of setting. I use a D90 and tried a different lens, which acted normally. I attached the malfunctioning lens to my D80 and it continued it's erratic actions. Therefore I believe the problem is with the lens, not the camera.
Anonymous
Level 3:
Brigadier General:
  • Master 3,006 Answers
  • Posted on Jun 30, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3006
Questions
0
Helped
959172
Points
10121
Your lens is a cheaply-built kit lens intended to be sold as part of an initial body and lens kit.
It's not built badly or with especially poor quality materials, but it's certainly not to the same standard as their non-kit lens offerings and so is not as long-lasting or robust as regular Nikon lenses.
In your case, the focus drive mechanism has broken, possibly due to one of more motor pinion teeth being stripped. If the lens has not been dropped or otherwise misused and is still under warranty then return it to a Nikon service centre for a free repair. If outside of the warranty, then in most countries Nikon offer fixed price repairs, but you'll find it more economical to simply buy a replacement lens. What's failed is not suited to a DIY repair
You can commonly buy new ex-display examples and definitely fully-functional used examples of your lens for a less than the typical fixed repair price. As you don't state which country/stat you live in, I'm unable to provide example prices.
Testimonial: "Excellent information. Much appreciated. Thank you."
Autofocus not working
Have you tried to see if you camera is running the latest firmware? If its not update it.
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
5helpful
I have a Nikon D40x and purchased the AF nikkor 50 mm f/1.8D lens a couple years ago, but find that it can only be focused manually. Is there any way to "turn on" the autofocus? I have not had...
Sorry, but the D40x lacks an autofocus motor, depending on the lens to have one. Nikon calls such lenses AF-S. This particular lens does not have such a motor, relying on the camera to have one. The only 50mm lens currently available with an autofocus motor is this one:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/2180/AF-S-NIKKOR-50mm-f%252F1.4G.html
Earlier this week the Nikon web site listed a new 50mm F1.8 lens with an autofocus motor, but then it was removed. Hopefully they will officially announce this lens soon.
My lens isn't focusing as fast as it use to and is noisy when focusing now. What could the problem be?
Assuming this is on a d40/d40x or similar camera without a motor in the body. What is happening is your lenses motor is wearing out and is no longer as functional as it once was.
9helpful
I got this lens (Nikon AF NIKKOR 50mm f/1.4D) for my D3100 and it doesn't autofocus. I don't knowhow to intervene since there's no switch on the lens itself (because I understand it is small and it doesn't...
The D3100 can't autofocus with this lens. The D3100 does not have a focus motor, depending on the lens to have one. The AF-Nikkor 50mm doesn't have a focus motor, depending on the camera to have one.
To autofocus, you need lenses designated AF-S.
The lens only focus at 18 mm, when usin the zoom it doesnt focus at all
Ether The optic sensor is bad, Or the AF Motor is bad. Needs to be service by repair shop, Focus has to be check and Readjusted.
1helpful
Nikkor af-s 18-200 VR not focusing
Please check your focus settings in the camera menu. Play around with the focus point from Single to 11 points. Also, try Auto mode as a quick way to test if the focus is working
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
