Question about LG LHD45EL Dehumidifier
Bucket full light blinks with display code of 01 when bucket is empty
  • LG Master
  • 43,501 Answers
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on Jun 28, 2011
6ya staff
SOURCE:
The "full bucket" light is blinking- and the
When the Bucket Full Light is on, none of the controls (other than the On/Off) will work. If you haven't
emptied the bucket, do so. Then make sure the bucket is reinstalled properly into the holder. Failure to do this will cause the Bucket Full Light to stay ON. While you have the bucket out, check the inside of it for a float valve. It may be stick in the UP position. If so, jiggle the handle to make it return to the DOWN position.
I hope this helped you and thanks for Choosing FixYa.
Aug 12, 2011 | Kenmore 54501 Dehumidifier
It flashes 01 on the display and the bucket full indicator light blinks and it wont run.
If the water bucket has not been emptied the until will not start. If it has, be sure that the bucket was reinstalled properly in the holder and is making contact with the Water Level Control Switch on the back wall, inside of the bucket holder. The bucket should be installed "squarely" into the holder from top to bottom. The bottom of the bucket should not tilt down at the bottom when installed properly.
Hope this helps and thanks for choosing FixYa.
Aug 04, 2011 | LG LHD45EL Dehumidifier
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Jun 07, 2010 | Dehumidifiers
The bucket full light blinks even though it is empty and there is "01" in the screen where the digital humidity level is indicated. Pushing the up or down arrow does not change the "01" number. Unit won't...
Take out the bucket and locate the bucket full switch inside the cabinet. Depress the switch and see if it comes on. If so, you may have to add a shim to the bucket or strap it in with a bungie cord as the bucket is jiggling and makes the unit think that it has been removed.
Jan 02, 2010 | Kenmore 54701 Dehumidifier
Unit will not run.
Error code 01 - unit has a sealed system leak; most warranties are 5 years.
Dec 30, 2009 | Kenmore 54701 Dehumidifier
Blinking bucket full light and humidity setting stuck at '01%'
yes but i might be late. if you still have this let me know
Jan 09, 2007 | Kenmore 54501 Dehumidifier
LG LHD45EL Dehumidifier Logo
656 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Gil Shultz
Anthony Ward
Anthony Ward
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
