I have a different model of RCA but had the same problem, try this: Code for Comcast Remote Control is 13183
Code for Voice Control Remote Control is 12292, however when you go thru the automated process of programming your TV you need to select TCL as your TV brand. Do not select RCA for Voice Control Remotes.
Anne try these codes if not use the links below.
3# codes 012, 013, 038, 086
4# codes 1003, 1054, 1055, 1062, 1109, 1130, 1170, 1246, 1253, 1275, 1277, 1286, 1289, 1350, 1389, 1392, 1406, 1418, 1419
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." RCA universal remote control codes for RCR450 RCR815 RCR412 and other...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
these are the codes: Code
:1000/3160/2000
for
RCA
TV/VCR/DVD
Code
:1000/3408/2000
for
RCA
TV/VCR/DVD but bear in mind these codes depend on the device in question.You can go to http://remotefinder.rca.com/default.aspx?site=rca
there are codes listed here for rca universal remote control where you can narrow your search by device type,model and other categories. good luck
aver si te ayuda esto
Code 000 for RCA TV
Code 003 for RCA TV
Code 004 for RCA TV
Code 005 for RCA TV
Code 006 for RCA TV
Code 007 for RCA TV
Code 019 for RCA TV
Code 054 for RCA TV
Code 055 for RCA TV
Code 082 for RCA TV
Code 096 for RCA TV
Code 098 for RCA TV
Code 099 for RCA TV
Code 100 for RCA TV
Code 101 for RCA TV
Code 102 for RCA TV
Code 103 for RCA TV
Code 129 for RCA TV
Code 179 for RCA TV
Code 181 for RCA TV
Code 188 for RCA TV
Code 190 for RCA TV
Code 196 for RCA TV
Code 202 for RCA TV
Code 203 for RCA TV
Code 212 for RCA TV
Code 215 for RCA TV
Code 233 for RCA TV
Code 281 for RCA TV
Code 352 for RCA TV
estos son los codigos
I finally found a code that works. Code 3144 worked. I am using the RCA universal remote control RCR412S and RCA DVD player DRC200N. The code 3144 is listed under Memorex in the code book that came with the remote control.
