Mitsubishi WD-52531 Television Logo
Anonymous Posted on Jun 28, 2011
The lamp light is blinking orange and we just replaced the lamp! on model WD-52531
TV Doctor Repair Consult
Level 3:
  • Master 373 Answers
  • Posted on Jun 28, 2011
Master
Level 3:
Answers
373
Questions
Helped
93032
Points
1011
You may have not plugged the lamp in fully or have not put the lamp door back properly. If you have done this properly and have the blinking problem then you are likely to have a bad ballast. This ballast supplies the voltage to light up the lamp. But first look on the front of the set for a small push button that says "system restore/reset". Use a ball point pen to press.
  • qwanjones97 Jun 30, 2011
    i had this problem 4 my wd73733 73in' Mitsubishi tv and thanx 2 u its wrking.
Bad Lamp for TV
Can't get a reception with my ws-a55 tv
Thank you but i think i found out whats wrong with it it was the light that blow
Lamp is bad--customer replaceable--Google the model number with the word "lamp" to locate a replacement---get one with the Mitsubishi name on it
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
1helpful
Blinking orangr lamp light
It is time to change the lamp.It is building up internal resistance and it will get to the point it will not come on at all, change the lamp.
Mitsubishi WD-52531 not working after replacing the buld.
Check to make sure the lamp is in correctly and that you've closed everything up properly. If you don't close the cover, the sensors will tell the computer in the TV that the door is open and won't let the TV turn on.
Other than that, could be a bad lamp or bad ballast.
Always buy OEM lamps, or better-than-oem equivalents! Philips lighting is the best lamp manufacturer out there for these TVs. They invented the thing!
Buy from Authorized distributors, and don't buy the "cheap" stuff. savnig 20 bucks will cost you more in the long run--believe me!
1helpful
Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Same problem with Mits WD-52531
The first thing to try is to reclose the access door to the lamp area. There are interlocks there that may be marginally connected. Try to reclose all access doors and report the results here.
Thanks,
Dan
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
