Canon LaserShot LBP5050N A4 Colour Laser , 9600x600 dpi, 8ppm colour/12ppm mono, LAN, USB Printer Logo
Posted on Jun 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is a red light flashing beside the triangle symbol on my cannon lbp5050n. What does this mean?
Corne Viljoen
Level 2:
  • Expert 385 Answers
  • Posted on Jun 28, 2011
Corne Viljoen
Expert
Level 2:
Answers
385
Questions
0
Helped
107724
Points
969
Hey!
If that happens look in the system tray for a yellow tiangle,click on it and it will tell you the problem!It might just be a empty toner!
Hope it helps!
1helpful
Doro Flip Phone. I have a red triangle on text messages on my phone?
Question edited for clarity.
Question moved to a better category.
Hello Maurice
questions like this really need to model number of model name. Doro make lots of flip phones. There are various ideas here in the links below.
Remove battery to reset.
Your data usage is exceeded.
The text wasn't sent.
What does an exclamation mark in a red triangle next to a text ...
https://www.cellphones.ca > answers > what-does-it-mea...
Oct 9, 2014 - What does it mean when there is an exclamation mark in a red triangle next to a text message? It shows part of a text when I open it up none ...
Red Exclamation point...... - HTC Droid Incredible - Android ...
https://androidforums.com > ... > HTC Droid Incredible
May 4, 2010 - The red triangle with the exclamation mark is showing up because somewhere in the string of texts you've been sending to this person, you did ...
16 posts · It comes up when sending text messages. Not in the messaging widget, but when you actually ...
W\hat does it mean when i see a red exclamation - Fixya
https://www.fixya.com > Forum > Cell Phones
Nov 20, 2019 - Hello, Normally, the red spot on an envelope in the sent messages means that your text has not been delivered to the destination phone number the text was sent ...
1 answer · 3 votes: Hello, you don't have to be bothered my friend,the red exclamation sign simply indicates that the message is broken along the way which means the message ...
SOLVED: Hi, my husband has a Doro 508,a big red ...
1 answer
Sept 16, 2019
SOLVED: Red triangle appears when text message sent ...
1 answer
May 14, 2015
How do i get rid of red exclamation mark on text ...
1 answer
Aug 21, 2014
What's the red triangle symbol on the android - HTC ...
1 answer
Apr 7, 2011
More results from www.fixya.com
What does the red triangle mean beside my "sent message?
https://forums.androidcentral.com > ask-question > 590...
Oct 5, 2015 · 3 posts · 3 authors
As keyree said, it means the message has not been sent. You should be able to tab the message and hit resend or retry. 10-06-2015 03:50 AM.
Meaning of Exclamation Point in a Triangle - texting ...
Aug 23, 2010
how do i get rid of the red triangle with the exclamation ...
Feb 19, 2016
More results from forums.androidcentral.com Missing: Doro ‎' Must include: Doro
How to remove the triangle with exclamation mark ... - AskingBox
https://www.askingbox.com > question > how-to-remov...
Oct 31, 2013 - The symbol "triangle with exclamation mark" in the status bar is a common symbol for a warning. In your case, that is the data usage warning.
I have a triangle error symbol in the lower right hand side of my printer, it has a lightning bolt inside of the symbol........what does this mean?
Canon printer light blinking error is a common error. Each printer features a flashing light to indicate its functionality. With Canon printers, you have flashing green and orange lights to inform you of any existing problems. It is suggested to carefully observe the number of flashes or the pattern of blinking lights as this will help you to understand the problem. And depending on the pattern, you can follow our canon printer troubleshooting guide mentioned below to solve that issue.
What does triangle with lightning bolt mean on Canon printer?
The orange triangle with the lightning bolt comes on when the printer is plugged in. The white light above the power button is on, but the printer is otherwise dead.
What does the orange triangle mean on my Canon printer?
When a printer error occurs, the Alarm lamp flashes orange as shown below. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error. Power Lamp Flashes Green.
What does the triangle symbol mean on my canon printer?
Seeing a yellow triangle with an exclamation mark usually indicates that a hardware device needs to be updated. If you are seeing the mark in Device Manager, we recommend checking the device status of the printer driver.
What does the flashing yellow light mean on Canon printer?
When an error occurs in printing such as the machine is out of paper or paper is jammed, a troubleshooting message is displayed automatically. Take the appropriate action described in the message. When an error occurs, the Alarm lamp flashes orange and a Support Code (error number) is displayed on the computer screen.
How can I rectify canon mp210 printer ink absorber full
Are you using fine ink cartridges? Is your printer still working normally besides the flashing lights?
1helpful
WHAT THE SYMBOLS MEAN
From left to right:
(Lights)
Exclamation point: Error
Weird Monitor beat symbol: Jam
Paper: Out of paper
Toner (Triangle leading down to dot pyramid): Toner refill
Lightbulb: ready
(buttons)
Greenish Play button (square with triangle): Continue
Red button with x: Stop/Cancel
Dell 2230 User Guide Page 1
Dash board light shows car in triangle with wrench beside it
{: ) The car-inside-triangle symbol is the Stabilitrak indicator and a wrench beside it means that a fault was detected on the Stabilitrak system of your vehicle and need servicing.
1helpful
What does the triangle symbol with small objects in it mean?
It´s the descaling indicator, you need to descale the machine.
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
11helpful
3answers
Flashing red symbol like a bowl crossed out
it means you have no back up battery installed to save time/date info. I know on the GL2 if you open the LCD screen there is another small plastic tab you can open and insert a relatively small battery. Do it and the icon will disappear. Otherwise its no big deal. If you dont need time/date stamps on your tapes then there is no need to install the battery unless you are just annoyed.
old marine
old marine
ZJ Limited
ZJ Limited
