SOURCE: one color missing
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
SOURCE: check black cartridge message
This happens if you refilled the cartridges, and forgot to take out the air..
Follow this steps..
1. Switch on the printer, open cartridge bay, remove cartridge, dont close the cartridge holder flaps, directly unplug the power supply from the printer end.
2. take a soft cotton, lint free cloth, slightly swab it with pure water, wring the cloth so any excess water is removed, and clean the contact pins inside the printer cartridge holder..
3. clean the cartridge head by keeping it in hot water (about 50C) and then wiping it clean, keep it upright for a few min, and when both printer and cartridge is completly dry put it back in, voila it should not display the message now...
SOURCE: I got a pink Fujifilm Finepix Z20fd and pictures won't download
You don't have to use the software that came with the Fujifilm. I have the same camera. If you're on a laptop that has a slot for SD cards, (if you have an SD card) you can just put your card straight into your computer and load the pictures that way. Also, if you have an SD card reader, you can use that. And if you're on a desktop without either of those options; once you plug your camera into your computer, go to your start menu and click 'My Computer,' then your camera should come up as a removable disk device in the folder. From there, you can drag and drop the pictures onto your desktop or your My Pictures folder.
SOURCE: Need to clean hp photosmart 7350 cartridge head
You can try manual cleaning :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
SOURCE: have a fujifilm finepix s1000fd and when I use
Your cameras focus lens is probably stuck.
It operates via a long metal rod, a pin which follows a track in the side wall of the lens and a tensioned spring. one or more of these has probably jammed causing the focus lens not to move when you zoom.
Unfortunately for this camera, if you cannot free it by switching on/off, tapping the lens etc, you will have to strip the camera down to get at the lens unit. you will have to discharge the flash capacitor before desoldering the control board from the main board before removing to access the lens.
Recommend you find someone who knows about this or send to Fuji.
