Crosley Radio Pictograph Slide Negative Scanner 1 ea Logo
Posted on Jun 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have installed Crosley CR5503A Pictograph Slide & Negative Scanner and when trying to start the program this message comes up: Cannot find camera- then connect your manufacturer- then acquire source failed, restart DSM Please help.
  • dwall35 Jun 29, 2011
    Problem solved. Thank you.
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Jun 29, 2011
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232015
Points
12714
Hi
This type of issues occurs due to unsuccessful installation of drivers or poor USB connection with PC and device. Make sure that the device and PC is firmly connected. Also check the availability of device from the properties in My Computer. If Camera is displaying in the Imaging Devices then the drivers have been installed successfully. If not then you'll need to uninstall and re-install the drivers. Hope this helps...please post back for further assistance.
Daniel
1 Related Answer
richroth
Richard Roth
  • 9472 Answers
  • Posted on Sep 20, 2011
SOURCE: I have installed Crosley CR5503A
You might have installed the wrong driver for your computer's operating system (OS) version. Uninstall the driver then check the OS version (32-bit or 64-bit). Right-click on My Computer (Computer) then selectProperties.
The system information of your computer will open then look for the system type.
Once the system type is determined, reinsert the driver CD then right-click on the CD-ROM drive and select Explore.
The contents of the driver CD are listed. Open Driver folder then select and open the driver folder for the OS version (32-bit or 64-bit) of your computer. Right-click on the setup.exe (setup) file then select Run as administrator.
The driver will install until a notice is shown that the scanner has been install successfully.
You can address the "Acquire Source Failed..Restart DSM" message by right-clicking on the scanner button at the status bar then selecting Maximize. jan_mczeal_3.jpg
A window will open. Click File and select and click Select Source.
Highlight (Click) the name of the correct scanner installed then click the Select button.
You should now be able to use the scanner.
This is My 3RD ATTEMPT to ask for a solution to your non-working Crosley Photograph film scanner. It showed photos but will not copy. Now it won't show photos either! HELP!
Patience is a virtue.
As to your questions, your machine must have come with a user/service manual. Get a hold of it, and read it. Where do you think I would get the information to give to you? Yes, I look for the manual on the Internet. I checked but could not find any to download or read online.
Says something about class installer will not install
What are you installing it on? IF you are putting it on a machine that has operating system like windows 7 or 8, you have the wrong software.
I've installed the sotware,but when I go to run it, it gives me some error message about DSM. Is there anywhere else I can access the driver software?
i think that it just does not work i am getting all the same stuff that all of u guys are getting and i have a top of the line computer so its not my computer its this fu**ing crosley scanner its **** i payed a lot for it and i am not to happy why is it still selling if everyone is getting the same stuff over and over not to happy
I just recieved a crosley slide and negative scanner, however, it came with NO instructions. Is there a manual available?
There should have been a quick installation guide in the box, if not,the manual is on the installation disc
3helpful
Top Crosley Washing Machines Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
