SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
SOURCE: printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
SOURCE: Richo 1515 MF Error message: 12320 couldn't find the scanner.
This is a message on your PC...not the machine itself obviously? Was this scanner ever configured to work on your PC? If not, then follow this link to my comments to someone else about this machine:
http://www.fixya.com/support/t1718617-ricoh_1515mf_scanning
SOURCE: Ricoh printer printing error: undefined offending command: mz
it is a logic card problem. so pls checked it from service center.
SOURCE: ricoh aficio 1515 with error code sc 392 and i
lets see if its a driver problem go to start go to devices printers now you should see your printer on the bottom half right click it the trouble shoot it the its going to ask you to fix then fix windows will take from there.
