Question about LG LHD65EBL Dehumidifier
Error message CH 24. Any ideas? I have the LD651EBL dehumidifier.
    New Friend:
We;ve managed to clear this error, at least for the last 5 days. Remove the bucket, and reach up behind the front panel where there is a filter- ours was covered in dust. After cleaning this off, and resetting the machine (by pulling the electric plug out and re-inserting), the error went away.
Your mileage may vary.
Posted on May 09, 2012
  • 1 more comment
  • kristin Jun 25, 2012
    This worked perfectly. I had to hit the reset button on the plug as well.
  • Susan Carr Oct 05, 2012
    Error 24 is usually cleared by simply hitting reset button on the plug or, as previously stated, unplug and plug back in. Sometimes, the removable filter is not properly seated. Error 67 requires cleaning the coils - not so easy. Needs a small hand and arm or a long brush.
  • William Miller
    William Miller Mar 28, 2018
    This worked exactly as described. Pretty shocking how filthy the filter screen was :-/
    New Friend:
Everyone's comments suggest the error goes away when you hit reset. Mine is hit or miss - I hit reset and sometimes it runs till the bucket fills up; sometimes I get another 24. The 24 let it into the shop when its warranty was almost up, and 2 months after coming out of the shop, bang, it was back. "The shop" was an hour away, and 3 weeks before I saw my unit back. Should be LS - Life Sucks.
Posted on Aug 25, 2013
    New Friend:
Mine was doing this and it said it needed a sensor. There is a filter in the front. I cleaned it and the error message has been off 2 days and everything is working great. If you clean it then unplug it, it will reset.
Posted on May 23, 2013
I have a ld651ebl lg dehumidifier and error message ch25 comes on all the time I have tried everything I could think of any idea's
Posted on May 26, 2012
  • Jdshipley May 26, 2012
    It will all so only run for 5min's or so it doesn't matter what setting it's on
    New Friend:
    Problem Solver:
  • 5 Answers
The manual says call the service center.
Just wondering. Are you using the bucket or a hose.
Posted on Jul 21, 2011
  • CogDog Dec 06, 2012
    I was using a hose. Since cleaning it cleared the erro, no need to call service center!
6ya staff
SOURCE:
What does error code CH 24 mean?
The CH67 code is generally related to either a fan motor failure or a blockage to the air inflow. It is recommended to check the filter, and make sure that none of the vents are obstructed. If this does not resolve the matter, then the unit may require service. To make service arrangements, you may either contact our Customer Interactive Center at call_skype_logo.png800-243-0000, or you can check our Repair Provider Lookup on our website, at http://www.lg.com/us/support/repair....
Sep 01, 2014 | LG Electronics LD451EGL 45-Pint...
Lg dehumidifier ch 67 error
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
Jul 14, 2012 | LG LD651EBL Dehumidifier
I have a brand new LD651EBL. Picked it up this morning. Just plugged it in. Keep getting the CH 24 code. The bucket is all the way in. Is there a fix or do I need to return it?
There may be some packing material left in the bucket or tape that is holding the float valve in place. In which case, the float valve may be in the UP position, which tells the unit, that the bucket is full.
Check the top of the bucket for the float valve and make sure it's in the DOWN position. Reinstall the bucket 'squarely" in the bucket holder and making contact with the bucket safety removal switch on the rear wall of the bucket holder.
If this continues to happen, consult the Troubleshooting Guide in the Owner's Manual.
Hope this helps and thanks for choosing FixYa.
Sep 11, 2011 | LG LHD65EBL Dehumidifier
The dehudifier won't come on in and in the digital display the message CH 01 comes up. Any idea what the problem is?
CH 01 usually indicates that the filter is dirty and needs to be removed and cleaned. Turn the unit OFF and unplug it, before removing the filter. Never operate the unit without the filter in place.
Thanks for choosing FixYa.
Sep 07, 2011 | LG LHD659EBL Dehumidifier
The message reads CH-01. The water collection full light is flashing, but the bin is empty. Can you advise
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Sep 06, 2011 | LG LHD45EL Dehumidifier
I have a LHD 45ELY8 Dehumidifier and it keeps coming up with the error message CH 1 and says the bucket is full. There is no water in the bucket.
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Jan 08, 2011 | LG LHD45EL Dehumidifier
Gettin error code ch 01 wont run
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Nov 13, 2010 | LG LHD45EL Dehumidifier
Code (CH) (01) on front panel, what does it mean?
I believe it is a water tank code. Re-seat the tank, unplug wait 15 seconds and replug the power cord and see if this resolves the error.
Background relating to other possibilities.
When the water bucket reaches its capacity, the bucket switch opens to shut off the dehumidifier. If the bucket switch fails while it is open, it will prevent the dehumidifier from running. To determine if the bucket switch is defective, use a multimeter to test it for continuity. If the bucket switch does not have continuity, replace it.
Sep 17, 2017 | LG LHD45EL Dehumidifier
LG LHD65EBL Dehumidifier Logo
7,141 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Gil Shultz
Anthony Ward
Anthony Ward
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
