You know, it's really normal to touch it hot on the door side.
Because it has heater to eliminate moist build up that can cause rust.
Check the drain pan (that is full of water) for clogged.
Unclog it using flexible solid wire and insert it on drain pan tube.
After that, those leak will be minimize.
Thanks for asking.
