Watches Logo
Posted on Jun 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just had a new battery installed in a fila wind master watch. the hr, min and sec hands are spinning and it goes through the start cycle. not able to stop this. also need instructions on how to set time. can't find my watch manual.
Anonymous
Level 3:
  • Master 1,833 Answers
  • Posted on Jun 29, 2011
Anonymous
Master
Level 3:
Answers
1833
Questions
0
Helped
554886
Points
4774
Hi, According to your problem first make sure that the battery that you have changed is OK, or try another battery. Your watch need a factory reset. If normal factory reseting doesn't solve your problem then you have to repair the machine.
Mens Fila Globetrotter Watch
Contact them direct as there is nothing online
http://filatime.com/
There is one manual but no analogue hands.
https://www.google.com/search?q=Mens+Fila+Globetrotter+instructions
Sep 19, 2023 • The Watches
tip
TACHYMETER/TACHOMETER - how to use it.
Many of watch brands has outer bezel ring calibrated as TACHYMETER/ TACHOMETER. In simple words this is SPEEDOMETER on your wrist, like in your car. The only difference is: it does not work automatic, but you have to have some maths basics in your brain to make work it.
The main thing is: As second is taken as measuring point (any wristwatch is moving sec by sec, min by min, hr by hr and so on), there is no actual possibility to measure speeds less than 60 km/h. This is because our time is divided to hours, minutes and seconds (1 hr=60 mins= 3600 secs), but ordinary watch on your wrist can't count smaller than a second, so, the starting point still is 60 for the majority.
The best watch tachymeters are producing/manufacturing BREITLING, as they have very long relationship with aviators all over the world. Braitling watches can count up to 1/10 of second.
OK, here is the link to learn basics of how to use tachymeter:
http://www.mydigitallife.info/2006/12/10/how-to-use-tachymeter-function-on-watch-bezel-usage-instruction-and-definition/
on Aug 06, 2010 • Watches
1helpful
My Sportek Watch (Alarm Chronograph Water Resist 30 m, with velcro band).... I can't reset it...lost manual
you may find a manual from the manufacture. hold the mode button down 3-5 sec's. the hr should blink ,use the opposite side buttons to change the number, then press mode again mins blink change, do this and set hr,min,sec, am or pm? then date month,day yr. press final time and time should be shown with no blinking. you can also hold in all buttons and let beep 5 times it resets to zero defalt settings
Jun 17, 2011 • Watches
1helpful
I have an armitron all sports mens watch I need to know how to set date and day of week
press in the mode button lower left or the top may say set hold to set, when blinking hr set number by using the right button set up or down , set press mode again goes to mins, then sec. then day and time. press until all set and all showing corrct numbers. then it is set
Do I need to wind a Fila Chronograph Automatic Watch
Under normal use winding an automatic watch is not needed.
If it has been left unused for more than about 3 days, then it will stop. On some automatic watches you can wind them but if yours does not allow this, then, holding it level (face up), swing it gently from side to side for a few minutes. This should wind the watch and after this normal use should be sufficient to keep it wound.
Set 24 hr hand
first click changes the date if you turn one way, but turning thr other way should change the 24 hour hand.
Nov 30, 2009 • Watches
3helpful
Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
3helpful
3answers
I can't find the user's manual for this watch: Armitron Sport 40/8125BLK Watch
You can download the user manual for your watch from this link(http://www.watchesmanuals.com/Armitron/Armitron-Sport-40-8125BLK-Watch.htm)
10helpful
3answers
Cannot get watch hands to sync with the digital time. mine is movement ''c320'' older watch, citizen ''navisail'' stars and stripes 2000 special edition....america's cup watch.
pull stem out and push all other buttons a b c at same time to reboot next step advance hands min/hour/sec to 12:00 push in stem M and start your reset
Top Fila Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Fila Watch Expert? Answer questions, earn points and help others
