Maytag PAV2300 Top Load Washer Logo
Posted on Jun 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drain leaking onto floor full force - Maytag PAV2300 Top Load Washer
danoyachtcap
Level 3:
Top Expert:
  • Master 2,907 Answers
  • Posted on Jun 29, 2011
danoyachtcap
Master
Level 3:
Top Expert:
Answers
2907
Questions
Helped
1275697
Points
52081
Check the hose from the washer to the sewer drain. A leak here is comon. You may have to remove the washer back panel if you cant see where the leak is.
Good Luck
Ice accumulates at bottom of refrigerator, water leaks onto floor if not removed.
sounds like a blocked drain, either by debris or failed drain heater?
Subzero 632 drain pan full of water and overflows onto floor
Dear,
Any one who charges that much for a "freon" leak in a 632 and does not replace the evaporator is a complete charlatan. Your "freon" will leak out again and more problems will occur.
regards,
dont rate it until satisfied
Model 795.71013.010 drip pan is full and leaking onto floor
Those models have problems with the defrost drain and defrost drain tube becoming blocked. Have you noticed water buildup on the floor of the freezer? See item 105A that is the drain tube.
http://c.searspartsdirect.com/lis_png/PLDM/F1002002-00002.png
That drain may have come unblocked because the refrigerator was off long enough for this ice to completely melt overflowing the ice trough seen in the video.
Appliance 911 Sea Breeze
My Maytag MZD2766GES is leaking water to the bottom of my freezer, which, when it get alot starts leaking all over the floor. where is this coming from?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
There is a hole in the bottom rear of the freezer of my side by side full of water and the over flow is frozen all across the bottom and it leaks onto the floor
How To Clear the Drain Tube Before clearing the drain tube, unplug the refrigerator or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard. Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
I have an 8 year old GE Profile Side by Side TPX24PB Refrig that is leaking water in the freezer, but not the refrigerator. There is a slab of ice on the freezer floor, eventually water runs onto the...
The drain is clogged. Remove the bottom bin out of the freezer. Once done you should see a trough at the back. This trough will be filled with ice, remvoe the ice. Then you have to clear the drain. The best way I know of to do this is to force hot water down the drain with a turkey baser untill water flows freely. Then mix baken soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Freezer drain not working. water accumulates and freezes in bottom of freezer compartment and sometimes will melt/leak onto floor
use hot water and turkey baster . force the water down the drain till it clear's to prevent it from freezing again install drain heater . some model's need them.
Smeg fride freezer leaking
HI Mark,
The evaporator drain is blocked causing the defrost water to pool, freeze and then leak onto your floor.
Clear out the freezer, then use a hammer to break up the ice on the floor. Now remove the rear panel. You'll see more ice build up. Don't use the hammer on it! (Too close to the coils for comfort) Use a hair dryer to warm up/melt the ice below the coils.
You'll see the drain hole now. Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
SG
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
1helpful
Water leaking onto floor from refrigerator/freezer
The defrost drain is stopped up. Without taking anything apart, the easiest way to clear the drain is to blow compressed air through the drain tube which is at the back of the Fridge. You'll see it..... it drains water into the drip pan. Hope this helps !
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
