I don't have any of that gear, but check that an option like "note on/off" is turned on in the MIDI setup menu on the Juno-D. Also check in Logic that it's midi is setup right. Logic could also be receiving sustain pedal MIDI info from the Juno. Anyway, that's all I got.
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Does the headphone jack work? Replacing a whole board would be expensive and the problem could be elsewhere. What was the accident? If large signals were driven back into the audio out lines, probably the output driver chip is fried... They likely use a common 8 pin dual op amp as the driver and the part costs 50 cents. It takes a little care to replace it as it is likely surface mounted. I am looking at the audio/jack board for a G-600 and there are a pair of transistors for some testing they do that could also be fried and might be the whole problem if the G-6 uses same or similar circuitry. The Fantom X6 uses very similar circuitry... Download service manual here:
Scroll down to "get manual" and click to download. IGNORE other download links. On page 57 of 66 you will find the audio drivers at the right. They use little dual op amps M5218APF which probably are available someplace, however probably 4568's would work fine and are readily available. If you drove high voltage into the audio outs, I suspect first that the RF bypass caps such as C203 on the above schematic shorted. Simple to replace... pennies apiece... The test path transistors such as Q37 may also be shorted... Next would be IC18... While this circuit may not be the exact one for the G6 it probably is CLOSE as the several Rolands all seem to use similar circuitry. Regarding system SAFETY... Make sure ALL and I do mean ALL equipment interconnected including mixers, powered speakers, keyboards, etc. are powered from the SAME receptacle or power conditioning module to avoid accidents. Also for keyboards sent to mixers, USE DI boxes please! These protect against ground loops and these accidents.
You haven't told us where the "sound" is coming from... If you are ONLY plugged in one channel that is all that will be recorded. We can't guess at how you are setup. Please provide an adequate description. If you only have a mono signal to start with, then get a WYE connector and jumper to the second channel.
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
Read page 135 regarding the note range settings. Look also for keyboard split information. You may have the keyboard set to NOT play notes in the top octaves for the particular voice you are using.
Hard to say as they are a very complex machine.
However have you tried a factory reset - check the manual - its a certain key/button combination.
You will losse any special settings but glitches are often solved by a reset.
Good luck
Bruce
This probably is not a DIY repair... The audio comes out of the CODEC and is buffered by Op Amp used as filters and then goes through the volume controls, After that it goes to the jack board with buffer OP amps. First thoughts might be a damaged volume control, however, the "B" outputs don't go through volume controls...
About the only thing I would think you could do is to CAREFULLY open the unit and look for a loose cable involved with sending the audio to the volume control panel and then the cable that takes the audio to the jack board...
More than that you would probably need to take it to a shop equiped to troubleshoot.
