it almost sounds like the temperature sensor is in the wrong place. that or the flow is inadequate for the heater to run. if you have a sand filter, put it on 'whirlpool' or 'recirculate' and try to run the heater.
First, create a shortcut on your desktop by right-clicking on the desktop, choosing New, and then choosing Shortcut. The Create Shortcut Wizard appears. In the box asking for the location of the shortcut, type shutdown. After you create the shortcut, double-clicking on it will shut down your PC.
But you can do much more with a shutdown shortcut than merely shut down your PC. You can add any combination of several switches to do extra duty, like this:
shutdown -r -t 01 -c "Rebooting your PC"
Double-clicking on that shortcut will reboot your PC after a one-second delay and display the message "Rebooting your PC." The shutdown command includes a variety of switches you can use to customize it. Table 1-3 lists all of them and describes their use.
I use this technique to create two shutdown shortcuts on my desktop—one for turning off my PC, and one for rebooting. Here are the ones I use:
shutdown -s -t 03 -c "Bye Bye m8!"
shutdown -r -t 03 -c "Ill be back m8 ;)!"
Switch
What it does
-s
Shuts down the PC.
-l
Logs off the current user.
-t nn
Indicates the duration of delay, in seconds, before performing the action.
-c "messagetext"
Displays a message in the System Shutdown window. A maximum of 127 characters can be used. The message must be enclosed in quotation marks.
-f
Forces any running applications to shut down.
-r
Reboots the PC.
Error 32 is a shutter related problem
Try this :- Switch off the Camera, wait 10 secs, Open the battery door and remove the battery, wait 30 secs insert the battery and close the door. Wait 10 secs switch on.
Precor Error 70, LPCA Not Read
Probable Cause
Incorrect or missing software in the LPCA
Corrective Action
Test with a known good LPCA
Precor Error 70 LPCA Not Read AMT12 Only
Hi. Press the power buttong for 10 secs inorder for the system to shutdown. Take out the battery and unplugged the power adapter. Preass and hold the power button for 30 secs then put everything back in. Turn On the computer.
The vibration of the move may have loosen the connectors. Unplug unit remove motor shroud you will see the motor control board pull and reconnect all connections also check the connector in upper electronics then on unit see your display works and see if you have motor and belt movement.
it dont make it all the time
