Hi shyamkhairna,
Your problem is caused by bad t-con board. You may look online for the replacement like ebay.com and shopjimmy.com.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
U still have Closed Captioning functions are on.Check ur remote control for a button that said CC.Used that button pushes couples times for all CC1,2,3 to off.Should have no more black squares showing up the tv screen again.
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get ur picture back.It a long board in shape.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
1) Connect your signal source - either CABLE or ANTENNA.
2) Go into your menu and select your signal source to match.
3) SCAN in the channels. This will give you all channels available.
Your User Manual will give you all information. If you are on cable, you may have to check with your supplier to see if they carry local stations.
