I have been given a Hoover model 1010 Elite 6kg washing machine. There is no manual and the face panel print has worn off. Would it be possible to get a picture or drawing of the face panel with the words. The washing machine works prefectly and I would like to be able to set the cycles properly
Thanks for your assistance
Wynn Sher
Australia
first check the water is switched on to the machine. If it is then you most likely have a faulty water valve. Switch all power off and remove the top panel should be 4 screws or so. If it has 1 valve then replace it.
Front cover held on by three srews at the bottom of the front, the front just sldes down when these are removed, we had a leak on ours and it was the pipe used to provide for the overflow perishing. (At the back on the right side looking from the frriont
Good morning! It's common to a washing machine to go out of balance everytime we exceeded the prescribed capacity load (as indicated in the enclosed manual upon purchase of the unit). the fitted new pump is not the source of such problem. Please try to review the manual of your machine and take note of the required capacity load which I think should not exceed 6kg. Best regards.
