RCA HD52W59 HDTV Projection Television Logo
Posted on Jul 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an rca hd52w59 projection tv. When I was watching it the other day the picture became distorted. Now when I turn it on, I have what looks like an upside down rainbow at the top of my screen. Bowing downward from right to left I have mulit colored lines and the picture is distorted. At the bottom of the screen the picture bows upward(arches up) and at the top of the screen the picture bows downward (arches down). What is going on?
Anonymous
Level 3:
  • Master 1,476 Answers
  • Posted on Jul 01, 2011
Anonymous
Master
Level 3:
Answers
1476
Questions
0
Helped
340227
Points
4062
Mcnamara724,
Bad convergence circuit. See my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics for repair help.
Thanks for using FixYa and for the great rating.
hardrocko
Our tv just had the three colors cross and picture became distorted, almost three dimensional. What could be the issue and is this an easy fix? The auto-convergence option is not showing up either on the...
Blowed Fuse on deflection board FL231. Deflection board is the bottom left hand side, and on the right handside of FBT flyback Transfomer is 3 Fuses in a Roll they will Look like Small brown rectrangler Caps But are Fuses it will be the Middle Fuse that is Bad.
Mats 1-800-628-1118
UED 1-800-648-6657
Hi I have a rca hd52w59. the top half of the
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2helpful
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
My RCA TV has a distorted picture.
Go to menu then setup see if convergence is listed If not you have a open Fuse FL231.
Convergence Problem RCA HD52W59
you need to test all cables then make shure it is not your tv.
2helpful
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
RCA HD52W59, Serial: G075CN0AO, Chassis # 1TC222A
ask your service depot about the service flash on the covergence connector,causes intermittant faults and deflection problems /
High pitch ringing noise and picture distortion
Sounds like the capacitor that goes bad just before the hIgh Voltage transformer goues bad. If i were you I would call an authorized RCA repair Shope and see if this is going to cause more damage to your set in the future.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
