Question about Chamberlain & Liftmaster Garage Doors
Have an old superglide model G-6456.Recently opened door which quivered while beginning to open about 2' and stopped.when I lift door very slightly with my foot it then opens completely. Today door would not open.The opener breaker was tripped.Reset.Door opens but again quivers while opening. Would this be a V belt issue? tx.
Anonymous
SOURCE:
Anonymous
SOURCE: Chamberlain Whisper Belt Drive
door does not close without holding wall button in
Posted on Nov 21, 2008
Anonymous
  • 244 Answers
SOURCE: Chamberlain garage door opener won't close
read manual, if you have, on trolley engagement
Posted on Jan 17, 2009
glenmann62
Glenn Mayer
  • 91 Answers
SOURCE: Chamberlain garage door opener unit-is it compatible with craftsman keypad?
Hello,Linda well this is your lucky day ,I have installed garage door openers for sears for 10 years and i can tell you that craftsman,chamberlain ,and liftmaster are all the same machine and manufactured under the liftmaster name , if you buy it from home depot it will be a chamberlain ,if you buy it at sears ,it will be a craftsman, and if you go to commercial building supplier it will be a liftmaster! now getting that out of the way even though they are all compatible ,there is one thing that stands in their way and that,s time ,For example if your chamberlain machine is 5 years old and you went to sears last week ,the chances of the frequency being the same are not good , most likely you have the wireless keypad , one way to test the sears keypad against the chamberlain machine is to locate the smart button on your machine ,this button allows for programming of remotes and keypads , to test and see exactly what im talking about take your remote and locate the smart button ,if you have three buttons on the remote press one of the buttons that are not being used on the remote ,above the smart button their will be a blinking light ,if you press your remote button you will notice the light go from a blink to a rapid flash , This is telling you that you are sending a signal for programming to the machine , well the keypad is exactly the same all you have to do is push the enter button on the keypad and have someone watch for the rapid blinking light ,if they are compatible the light will blink rapidly on the machine so all you have to do now is have someone press the smart button once on the machine your indicator light will now be a solid light you will have approx 60 seconds then to put a 4 digit code in the keypad and then press and hold down the enter button on the keypad , at this point you will notice the lightbulbs on the chamberlain machine to shut off and come back on this is to tell you that the machine accepted the code , after thats been done you can use your keypad , you can also find the owners manual to the chamberlain and follow the same instructions to programming the remote , they are identical in programing , if your keypad is not the same frequency you can also tell by looking at the frequency code on the backside of the keypad and also the chamberlain unit usually where the light bulb is will be its code
Posted on Mar 04, 2009
Anonymous
  • 12 Answers
SOURCE: need to replace carriage on stanley sd450 opener how is it done?
Please make sure you don't have broken springs first and that the door is balanced properly. If so you can replace the "Trolly" by disconnecting the arm from the opener, undoing the opener from the bracket that mounts it to the wall. This usually takes a 1/2 in wrench. Then swing the opener out far enough to slide the trolly off and replace it with a new one. Re-connect everything then re-engage the trolly.
Posted on May 19, 2009
Anonymous
SOURCE: Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Posted on Dec 17, 2009
I recently bought a Chamberlain 3/4 hp belt drive MyQ garage door opener. I had an old garage door that I thought was bad, I'm not sure now. The old door opener would lift the door about a 1ft to a 1 1/2ft...
How is the door balanced currently? In manual setting (without the opener) can it be raised by hand, will it hold at it's halfway point, and will it hold at fully open?
These all have to be be in balance before adding the opener.
I just replaced my rollers (Ideal Security SK7123 1 7/8-in Deluxe Nylon Rollers Commercial Grade 11 Ball Bearings) and they made a world of difference to quietness and opening. Plus, more importantly, they gave me clues as to the RHS being misaligned.
There are several videos out there dealing with door side to side imbalances also.
Apr 07, 2014 | Chamberlain Whisper Drive 3/4 Hps Garage...
The lights on my liftmaster garage door opener suddenly stopped working I have already replaced the old light bulbs with ones I know work but the lights are still not working.
Unplug the opener and remove the light bulb. Using a small screwdriver lift up on the center contact of the socket. Replace the bulb and plug the opener in.
Oct 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster garage door only opens 8 inches and then stops
It sounds like the opener is stopping because the weight of the door is tripping the lift sensor on the opener. There are two screws on the side of the opener to adjust the lift and close pressure. Find the lift pressure screw and ajust it higher to see if that remedies the problem.
Also, because you said the door will not stay open at the top when you open it manually, I think your springs are not adjusted correctly. They should hold the door open in the up position when not connected to the door opener. That may be the reason the opener lift pressure is kicking it out.
If you have to adjust the springs, be careful that you know what you are doing. There is a lot of potential for getting hurt if you don't know the proper proceedure.
Good luck.
Jan 17, 2010 | liftmaster Chamberlain Garage Door Opener...
Door barely opens/ opens with physical lifting assistance
It sounds like you have a broken door spring or the drive gear in the opener is stripped. You will have to take the cover off the opener and you will find the white nylon gear just in front of the motor.
Sep 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Professional Line 1.5 hp won't open the garage door
Sounds like a bad spring or the drive gear is going bad. Take a good look at the springs above the door. It is sometimes hard to tell when one is broken. Remove the cover and look at the gear. It is obvious when this is going bad.
Aug 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door does not open all the way stops @12 inches
You most likely have a broken door spring. Release the door from the opener and try lifting it by hand. Look above the door for the springs.
Mar 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
CRAFTSMAN GARAGE DOOR OPENER PROBLEM
i have a garage door opener craftman 1/2 hp model 13953985 the light is flashing 10 times . now you have too hold down on the button to raise and lower .
Feb 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change the freqency on a lift master garage door
Chance are they set there remote when you were using yours. To reset your opener you need to clear all the codes on the back of your opener itself there is a square button purple or red depends on how old it is. Press and hold that button until the LCD light turns off. Press your remote to make sure it has stopped working. Then press the button again only for a sec until the light comes on and starts to flash then press your remote button. Repeat for each remote.
Feb 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain & Liftmaster Garage Doors Logo
230 people viewed this question
Top Chamberlain Building Materials Experts
Ross Metcalfe
Ross Metcalfe
deton8 von Splosion
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
