The two halfs of the rear handle do not seperate, once you have removed the r/h side grip you can remove the throttle lock, you then need to remove the pivot pin from the trigger with a pin punch, the trigger can then be pulled down and out, you may need to disconnect the throttle wire from the carb if you cannot drop the trigger far enough to remove the wire from it.
