Question about Freezers
Water Dripping Inside
We have a Samsung American style fridge/freezer and 3 days ago we found large amount of water leaking from it, we opened the freezer door and found water at the bottom of the freezer, this fills up every 2-3 days then starts to leak, we put some kitchen roll down to absorb the water, but have to change this every 2-3 days once it becomes saturated
Can anyone help?
  • kdevlukia Aug 25, 2008
    Dear Neil
    No air coming in from outside, the water is leaking into the freezer from the back of the freezer, there are these plastic grate openings inside at the back and water drops come in from there and then pool at the bottom.
    Do you have any other ideas what it might be
    Kind Regards
    Kailesh
  • kdevlukia Aug 26, 2008
    Dear Neil
    Someone has told me its a blocked freezer drain, model Samsung RS20CCMS
    So question is how would i unblock it.
    Best Regards
    Kailesh Devlukia
    Problem Solver:
  • 3 Answers
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Posted on Oct 18, 2010
  • 639 Answers
Hi Kdevlukia,
Happy to help you!!
Sounds like an air leak!
is there Ice build up around the door alowing outside air in?
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
  • Anonymous Aug 25, 2008
    Hi Kdevlukia,
    Happy to help you!!
    How old is the unit?
    If it is 10 years old or more it's not worth fixing becaue the new units use MUCH LESS ELECTRICITY!
    If not then I think it is low on freon or a bad thermostat.
    write me back the yearof it!
    IN the USA
    Neil
  • Anonymous Aug 26, 2008
    Hi Kdevlukia,
    Happy to help you!!
    unfortunately form what I hear from you, I think you must call service!!!!
    They are open 7days/24hours nation wide.In the USA
    1-800-905-9505
    Neil
6ya staff
SOURCE:
Why is ice forming under the bottom drawer of my Samsung American fridge freezer Rsa1shpn and then water eventually leaking out the door? I have defrosted the fridge freezer but still have the problem
There is a drain tube located under the panel of most freezers. If that clogs up, the auto defrost can't work. The freezer defrosts by evaporating all the moisture out of the compartment. So, check that first. Secondly, a leaky door seal can also cause that problem. You can order door seals online or on Amazon.
Oct 17, 2014 | Samsung Freezers
THERE IS A GAP BETWEEN THE TOP OF THE MAGNETIC SEAL AND THE FRIDGE COMPARTMENT, THE DOOR CAN BE LIFTED UP, IS THE A SPACER AVAILABLE TO FIT TO THE BOTTOM OF THE DOOR TO COMPENSATE THE GAP. THANKS Frank...
Good day,
Just go to your local appliance parts house. They will have the shims you will need. Remove the top bracket, open the door slightly, and lift the door off. Install the number of shims necessary, and reinstall.
If it has a cam style bracket that helps close the door, replace it as well. It just bolts on, once the door is removed.
Nov 22, 2010 | Frigidaire Freezer Refrigeration White...
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
We have bought a new american style fridge/freezer and it was delivered yesterday. We have left it on for 24 hours and the temperature is not going down the fridge wont go below 12 degrees and the freezer...
ambient temp 10/35 degrees C.not in direct sunlight,
did you use a level to make sure that it is level in all planes,just to make sure all the door seals are tight,
(look along the seals to make sure)the unit should be left on for at least 24 hours in its chosen position with the doors shut,then check temp,it could take another 12 hours to settle down once loaded.Also make sure that its not touching the wall cuts down on vibration.
once checked,if still not right call samsung..they are good.
Apr 04, 2010 | Freezers
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Samsung side by side American style fridge/freezer
make sure your fan is running in freezer section. you should hear it
Dec 02, 2007 | Freezers
Freezers Logo
474 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
