Olympus Camedia D-425 / C-170 Digital Camera Logo
A
Anonymous Posted on Aug 31, 2005
Record mode What size are the digital pictures in each record mode?
Anonymous
Level 3:
Master:
  • Master 852 Answers
  • Posted on Aug 31, 2005
Anonymous
Master
Level 3:
Master:
Answers
852
Questions
27
Helped
95117
Points
2489
2288 x 1712 SHQ, JPEG - approximately 1960 Kb 2288 x 1712 HQ, JPEG - approximately 762 Kb 1600 x 1200 SQ2, JPEG - approximately 465 Kb 640 x 480 SQ2, JPEG - approximately 72 Kb 320 x 240 HQ Movie - approximately 12.5 Mb (20 Second Movie) 320 x 240 SQ Movie - approximately 12.5 Mb (41 Second movie)
1helpful
2answers
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
2helpful
Can't change image size
To change the image size in your camera to shoot at a lower setting - have the camera in shooting mode - go to Menu - go to the symbol that looks like an arrow pointing to the left - Press Ok - then select which record mode you want and press ok.
2answers
Reducing image size
You can change the record mode in the camera to shoot at a lower image size of 640X480 by changing from HQ to SQ mode. Page 72 of the instruction manual explains how to change the record mode setting. You can also use photo editing software to reduce the image size down to 640X480 which is equivalent to the size of a 3X5 photo.
No Manual (instructions) for Jazz hdv178
Press RECORD/PLAY Button to switch from Record Mode to Playback Mode.
The Playback Mode is for viewing and managing movies and pictures as well as listening to voice and
music on the built-in memory or on an optional memory card.
Operation Display Screen
Press RECORD/PLAY Button ( ) to switch
from Record Mode to Playback Mode Main Menu.
• There are 4 options in the Playback Mode, movie,
picture, music and voice.
• Direction Buttons can be used to select the
specific option.
• Press OK Button to view movies/pictures, listen to
voice or music.
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Features of each record mode
The details for each record mode are as follows: RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth. TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer. SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored. HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ. 3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode. SQ1/SQ2: SQ1 is used for resolutions above 1600 x1200 and SQ2 is used for resolutions below 1600 x1200. For both, you can choose high compression to reduce noise or normal compression to save more images.
Features of each record mode...
The details for each record mode are as follows: RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth. TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer. SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored. HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ. 3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode. SQ1: SQ1 uses the highest compression for resolutions greater than 1600 x 1200. You can choose high compression to reduce noise or normal compression to save more images. SQ2: SQ2 uses the highest compression for resolutions less than 1600 x 1200. You can choose high compression to reduce noise or normal compression to save more images.
Compression rates
Record Mode Recording Size (Resolution) Compression SHQ 1600 x 1200 Approx. 1/2.8 HQ 1600 x 1200 Approx. 1/8 SQ1 1024 x 768 Approx. 1/6 SQ2 640 x 480 Approx. 1/4
File sizes
Record Mode Recording Size (Resolution) Max. File Sizes SHQ 1600 x 1200 Approx. 1.3MB HQ 1600 x 1200 Approx. 418KB SQ1 1024 x 768 Approx. 213KB SQ2 640 x 480 Approx. 140KB
Digital pictures size
SHQ 2288 x 1712, jpeg, approx. 3.1 MB HQ 2288 x 1712, jpeg, approx. 990 Kb SQ2 1600 x 1200, jpeg, approx. 450 Kb SQ2 640 x 480, jpeg, approx. 77.8 Kb HQ movie 320 x 240, approx. 12.5 MB (20 second movie) SQ movie 320 x 240 , approx. 12.5 MB (41 second movie).
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
