I buy all my supplies including bows, arrows, targets and protective gear from http://www.cabelas.com/archery.shtml They got a wide variety of accessories for archers and their products are top quality although a bit expensive.
Most people are either naturally left eye dominant or right eye dominant, but most people are neither. In archery and other target based sports, this allows you to aim the sight at a target. From the eye dominance you should know which bow suits you, left or right handed bow.
In general it is best to have an ample supply of the same or similar bow types. You need to have bows, arrows, quivers, arm guards and a finger tab. Targets are also necessary for your archery stock.
Leapster L-Max recalibrates differently. I was trying to use the instructions and it kept asking for a blue button. For the Leapster L-Max push B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take several times to get it working again.
