Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a whirlpool- cabrio and 5D or SD error code appears. What is the problem and how do you fix it.?
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Posted on Jul 02, 2011
  • sissytimber Nov 03, 2011
    I'm having a problem with my washer it is showing 5d and sometimes LF not sure what to do.
    New Friend:
The reason people ask these questions is to not have to call a service tech. I know I paid enough for this washer to not have to go broke servicing it. I'll never buy a whirlpool washer again. It's been nothing but trouble.
Posted on Feb 28, 2015
    New Friend:
Call for services to Yino Services & Repair Inc. Is a very good company and very professionals.
Posted on Jun 21, 2014
Anonymous
SOURCE:
My whirlpool cabrio washer wtw6200vwo shows f71code and wont spin out clothes
WHIRLPOOL CABRIO WASHER ERROR F71. The Cabrio Washer Error F71 code is the same as the SD code: This error means the main control board detects too much drag on the basket during the spin cycle.Mar 29, 2017
Nov 13, 2017 | Whirlpool Washing Machines
Cabrio washer 5d error code
chances are the 5d error code you see is actually sd. it is supposed to signal excessive suds in the water but it seems to show at other times as well. but regardless of the code and depending on you mechanical abilities, remove the center cap on top of the agitator, remove the bolt and remove the agitator. some force may be needed to get the agitator off the shaft, keep equal pressure 180 degrees apart and work around the base lifting the agitator, gently rock the agitator as you lift. when it comes off take the screws from the gear hub assy out, probably six screws. when the cap is lifted off you should find a small gear, pull it off the shaft, clean and look at the teeth inside. if worn, get replacement part. put back together and run a rinse and spin cycle or similar to see if it spins . hopefully it will solve your problem.
May 31, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Y whirlpool cabrio washer is showing code 5D how do I fix
SD is Sud lock, too much soap, or clogged drain pump. Also check the pressure tube, make sure no gunk is in it. If none of that works, then replace the main control board.
May 23, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Can not clear code sd
Oct 20, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a WTW6400SW2. Always get 5d code if we use high spin speed or do large load. Also seems to take forever for tub to drain. Related problems? In the past have epoxied exterior of drain pump due to...
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 15, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Cabrio washer is showing a 5d error and not spinning or draining well. What is the problem?
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Sep 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Is 5d or sd a code
SD is the code for suds detect. You may have used too much detergent, or you may not have used HE laundry detergent.
Aug 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio won't spin
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. ➔ Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction
its SD not 5D
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify: ➔ Load is bunched or twisted around agitator. ➔ Excessive detergent usage. ➔ Basket cannot engage during drain step. ➔ Mechanical friction on drive mechanism, not allowing basket to engage.
Jul 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
10,911 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
