I had a DE45EK-T for a couple months, when it displayed the E2 I tried
the various things on this site, Nothing worked, while looking around
the unit I popped off the control panel (it can just be removed with a
butter knife) somehow water was massing next to the circuit board. I
used a hair drier to dry it off and it worked fine after that (put a
shopping bag over the panel when I snapped it back in, hopefully that'll
keep it dry).
Good Luck.
Sueann, it may very well be a voltage problem, since it won't allow you to reset the unit, by pressing the reset button on the cord. Plus, there is no reference to it in your Owner's Manual. On Tuesday, call Haier Customer Support @ 1-877-337-3639 and one of their Tech Service people can advise you what the error code is and how to solve it. Since you've only had the unit a couple of weeks and the warranty is still in effect, it's the best way to handle it.
Hope this helps you.
Need make ,model # , s# get asap might be able to help
Haier, model # DE45EK-T S# AJ256E0000A94B470255 thanks
Thanks Gas Logs, I planned on calling them tuesday just thought I'd try this until then. It shouldn't be a voltage problem as the last one I have was twice the size but who knows. And I wish the manual had the error codes in them but it doesn't ugh. Thanks again
