It's giving a fault code of F35. Anyone know what this means?
This code is not on the list.
Try this:
Push cancel twice
Select drain and spin
Select your cycle and push start.
If this does not clear the code, you will need a service call.
Before you do that I am wondering-Are you using an HE detergent and in small amounts? Are you loading the washer evenly- for example towels with towels lingerie with lingerie and jeans with jeans. Front loaders are very sensitive to how they are loaded. Check everything you can:
Turn off the washer and unplug it. Grab some old towels and a bucket.
Check the drain hose- is it twisted, squished or plugged ( you can turn off the washer unplug it and remove the drain hose to see if it is clogged.) While you are back there check the incoming water hoses are they twisted? Unscrew them from the washer and make sure the little filters at the ends of the hoses are not plugged, so that water is coming in freely. Make sure water valves are turned all the way on.
When you are back in front examine the door seal. Is it in good condition? Give the tub a spin with your hand. Does it spin freely and does it feel secure?
Check your dispensers. Are they clean and empty? if they are not try running an empty short cycle with just a little Hot water in the liquid dispensers to see if they are plugged.
Okay. Good luck to you. I hope this can be solved without a service call.
thank YOu for using FixYA Ratings are always appreciated.
I had a suds error and then a F 35 error. Turns out I had a collection of junk and debris between the door seal and the drain at bottom of door. Cleared out the debris now my washer is running like a top. (washer senses pressure error, thats why I got said error codes)
I had a suds error and then a F35 error code.
I replaced the pressure switch PS1.
This fixed the problem
Apparently F35 means the washer WFW9600T has a broken part. I don't know which part yet, but it's being ordered. I'll follow up when I find out.
Fault code F35 for a Whirlpool washer/dryer duet WFW9600T means there's a part called a PSI switch that has to be ordered and replaced.
I have the same washer WFW9600. Just got back from a 3 week trip and never had a problem. Put a load in and it stops with F35 code. water and pump and drain seem to be working. Have unplugged and replugged. Have also suctioned the drain hose at the back with a wet vac.
