Quisas. Only if the control frequencies for both units are identical. Since you are dealing with same manufacturer you have a better chance of it working than if you were using two units from different manufacturers.
hi, BEARHOUSE IS HERE WITH THE Answer i Purchased a Memorex MVD2022 DVD Player at a Goodwill Store For $7.00 Dollars. I Had a Coby Model# 224 with Remote Control My Coby Quit Working the motor Drags. I had Both DVD Players on top of Each Other Tried The Remote For The Coby and The Memorex DVD Player Blinked. So I Cut off The Coby And What Did Find I Found that the Coby Remote Worked on the Memorex The Buttons Are Different But Works Good Enough For Me.
The Setup Button Eject the Disc and the >> fast Forward Button Turns it on and off and the Program Button works For Sub Title other Buttons have other functions for The MemorexMVD 2022 Only thing You Have to work the sound From Surround System are TV.
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Traditionally, universal remotes do not work with COBY dvd players. The fact that you've found one that works at all is surprising. There isn't a true solution to your problem, however, because Philips created the coding for that remote without any input from COBY. The only thing you can try is a different COBY code if there is one in the code section of the book that came with your Philips remote.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Unfortunately,
Coby is a company whose electronics cannot be controlled by any remote
other than the one that came with it. This means there is no code
available for universal remotes. If you need a replacement remote (it
will be identical to the one that came with the unit) please call our
customer service number above. They will take your information and
provide you with the procedure for ordering a part from Coby.
If
you feel this solution doesn't deserve a good rating, please let me
know why so that I may better assist you. If there is anything more I
can do to help, I will!
Unfortunately, Coby is a company whose electronics cannot be controlled by any remote other than the one that came with it. This means there is no code available for universal remotes. If you need a replacement remote (it will be identical to the one that came with the unit) please call our customer service number above. They will take your information and provide you with the procedure for ordering a part from Coby.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Unfortunately,
the dvd 224 doesn't have a volume adjustment. The models that do are the ones that come with 5.1 surround sound speakers such as dvd 755, dvd 937, and dvd 958 just to name a few.
If
I sucessfully programed the AUX button on my Cable remote to my Coby DVD player (model DVD-227) using code 21107. You can also try these codes: 20778, 21086, 21351.
if coby is an independent company you are out of luck. Is coby made by a "master company"? (e.g. orion is made by emerson and their codes work for orion products)
