Televison & Video Logo
Anonymous Posted on Jul 04, 2011
I have a 3 year old Toshiba Regza model#40XV645U..all of a sudden the screen went to no picture..there is sound and its as if the picture is lying beneath a very dark blue screen w/ a very thin band of the picture visible on top of the screen..Verizon FiOS says its the TV..but I hardly watch it..and its only 3 years old if that..Help, can't afford a new one..
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
302
Points
Did u find out what the problem is. I have exactly the same problem and my TV is only 18 months old.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jul 04, 2011
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366120
Points
33650
Breaking down after 3 years is about right for LCD TV. It sounds like the T-CON board has gone out. Does the on screen menu look normal?
Learn about failed T-CON/LCD panel here and also read my guide to understand more.
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
  • Anonymous Jul 04, 2011
    Thanks budmrtn,
    Really 3 years is about right for an LCD?..that's crazy considering how much they cost.
    I can't even see the on screen menu...as the screen is dark. What would you estimate the
    cost of repair to be..or should I just buy another??
    Thaks for your response.
  • Bud Martin
    Bud Martin Jul 04, 2011
    Typical repair will be $150 and up plus parts, estimate charge alone will be about $50 or more.
    Look at the screen in the darkened room to see if it has any glowing screen, if not it can be the backlights or the 24vdc power supply for the backlights has gone out. I see TVs less than two uers old that already break down, it does not matter what brand you buy, the only thing to watch out is that the company will still be around a year from now when the TV will need replacement parts.
Toshiba regza sound picture
It sounds that the back-light inverter bard has the fault. If you are somewhat sound in electronics, you can do the work by yourself. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ It has troubleshooting details to many brand televisions, including Toshiba. Pull up older post there, either by its left side bar, or, see it in 'Timeslide' option.
Toshiba regza tv switches on but has no picture or sound
I can try to help but: what is the model number and how old is this set? Model and date made will be on rear of set.
2helpful
Toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
8helpful
Toshiba Regza 40XV645U garbled sound. Have to turn TV off and back on to resolve. Recurrs after an hour or so.
There is an issue with the audio processor. Most likely it is the main board needs to be replaced in order to fix the issue. You will need to remove the back cover in order to get access to it.
There could also be an issue with the power supply supplying the right voltage to the processor. This can be checked by seeing if the 18V DC is present at pins 3 and 4 of CN90 on the power supply. If the voltage is present, then replace the main board. If it is not, replace the power supply.
My sound as gone on my toshiba regza tv
Does the sound icon move up like it should on the screen when you increase the volume?
Audio went dead suddenly and no sound with any channel.
Audio went dead with no sound on any channel. Signal was breaking up (picture was tiling). When tiling stopped, sound went dead.
Toshiba Regza 42" lost all hdmi input
TV was on, screen went black... Stanley cup playoffs double OT continued sound only. TV now just clicks on and off.
Was watching tv( Toshiba Regza)and the screen went blank.
I have the same television and ocasionally the sound shuts-off, but I still have a picture.
What type of cable system do you have? What kind of converter box? I am trying to find out if it is the TV or converter box. I change the channel a couple of times and the sound usually comes back.
2helpful
3answers
No picture, just sound
No new video card required. I just reset the television by holding the on/off button for five seconds (yellow light on front panel blinks repeatedly). I then cycled power using the remote control and my picture came back. Worked for me. Hope it works for you.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
