P0130 &p0134 are error codes for the o2 sensors
p1345 is an error on the cam speed sensor
two separate issues.
is this a rebuild? usually you wont get a p1345 unless you have made some adjustments to the cam shaft, unless you have been having some major misfires and your timing built or cam shaft is off.
the o2 sensors are easy enough to change and a cheap fix located in the exhaust manifold and before your cat converter. sounds like you are having some other problems though if all 3 sensors are going off.
