SOURCE: Unable to programme La Marzocco
FYI - the flowmeters can get fried after lots of usage. Back in the day Starbucks used to put pieces of cardboard between the flowmeter and group head to prevent them from heating up. Aside from checking for scale you use test with an ohm reader. I think a functional one will reach 2.4ohm (or maybe 2.8). A broken one will post junk ohm information and bounce around. Replacing them is expensive so I'd just recommend usitng the semi-auto on/off switches. This info comes out of the big oragne Linea maintenance book.
SOURCE: Problems programming La Marzocco Linea espresso
Check to see if the program switch is turned off. There might be a switch in the inside of the machine, or on the front panel and you need the key for you have to go through the cpu board.
SOURCE: how do I increase grouphead
To increase dispense pressure you turn the adjustment screw at the pump. When pulling a shot (use espresso) on one group the bottom needle of the gauge should read 9bars while pulling the shot.
