How to program an RCA xl-100 xs series to the remote
Hello In order for the 3 component universal remote to control your TV, you must program it with the TV code that matches your TV. These instructions explain the preferred method of 1* Manually turn on the TV. 2* Locate the enclosed TV Code List. Find your brand of TV. 3* Press and release the TV key. The 4* Use the number keys to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED will flash rapidly for 2 5* Aim the remote at your TV and press the ON•OFF key. If your TV turns 6* Enter the code in the box provided 7* If your TV doesn't turn off, repeat steps 3-6 above, entering the next
Your RCA remote universal remote control model number is RCA RCU300T; I thinks and poste this solution to you.
Codes for RCA tv with this remote control are:
000, 003, 004, 005, 027, 045, 077, 089, 090, 094
programming the remote-the Direct Entry method.
indicator light blinks and then remains lit
seconds. Start over at step 3.
off, you have found the correct code
on this page for future reference
code for your brand.
OK
SOURCE: program the RCA#rcr312 universal remote control
hold the code search buttton until light comes on then select the device you are programing and enter code
SOURCE: Programming a RCA Remote to a Zenith TV
this link will take you to the RCA site where you can access your remotes codes and instructions (model # of remote is listed on the back or under/inside the battery door in not on the face)
Thanks for using Fix Ya, please take the time to rate this solution.
clarkco.
SOURCE: need codes for rca universal remote rcr312w. for apex tv
With your model number at hand, check the RCA website for a later code list.
If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes.
At best, these should be called (honestly) 'multi-brand.'
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
