First configure dolphin internet access point on your phone. Dolphin customer care will help you with this. Then enable internet from your settings menu. It will work.
Probably the data is off, try going to Settings, More, Mobile Network, and check the Data Enable box. If you still can't get internet by enabling data, then your APN must be off. If you are still with T-Mobile, then go to Settings, More, Mobile Network, Access Point Names or APN. From here you can see which Access Point is check, troubleshoot by checking one of T-Mobile's APN and trying to use the internet without Wi-Fi.
Seeing your Phone companies can't help with OTA internet settings (by the way, OTA means Over The Air) for you to configure your phone, you may have to go the Manually configure your phone for internet route.
To do this, go to your SIM card network service provider website and download Manual settings for Internet access.
Open settings in your phone and navigate to either Network/Mobile Networks/APNs, etc and Manually configure your phone.
When completed, select Use as default data/internet access
Ask
your mobile service provider to
activate your phone's internet service. They will send you an automatic
text message with the settings for your phone. That's it.
contact your network provider and ask them to send the internet setting for your mobile.they will send you.save those settings.after saving restart your phone and activate your internet now. try to access the internet in your phone now.if still having the same problem then there must be problem in your mobile.try to format the phone.try to access the internet after re installing. this will definitely works. if still having the problem then you can contact your service dealer for this problem.
You may not have saved the settings for accessing internet from your phone. You will have to contact your service provider, who on demand will send you the required settings. You will have to save each one of them (around 5 settings will be send to you). After saving it, you can access the internet from your phone easily.
Best Wishes. Thank You.
you can get into this site http://eg.samsungmobile.com/eng/supports/configure-mobile-phones.do and click on " Accept Terms And Continue " and choose your mobile " samsung T519 " and click on "Setup your phone for Wap" and choose your contry and your network and write your phone number and click " send " then go back and click on " Setup your phone for Internet " and do the same brevious steps and you will receive messages on your phone install it and you will be able to access internet
Are you sure that you have internet access activated by your mobile operator? It needs to be activated on their end for you to be able to access the internet.
