SOURCE: memory unlocked password
What should we do if we forget the password? For S60 1st and some of 2nd phones, such as Nokia 3650, Nokia 6600 and Nokia N-Gage, the password is stored in a plain text file.
SOURCE: my memory card is asking me for password
if you cant remember the password then format it to be able to use it again. there is no program that would be able to detect or know your password. better format it!
thank you for using fixya
CHARCOIS
SOURCE: Nokia 5310 memory card asking for password after factory reset
dear,
did to check it by putting it into memory card reader or connect your phone with pc through software. if not, do it and format your card from there and then check it again. hopefully, the issue will be resolved..
goodluck........
SOURCE: i recently update my nokia
sir connect your cellphone to the pc and copy the datas to the pc then you format the memory card to remove the default password..................
Flashing is the only solution, but anyway Remove Memory Card,Sim Card and reboot by inserting only the battery.Try it for 2-3 times.If the problem still persist better to contact mobile repairing shop or follow this trick.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5130 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
