Canon imageRUNNER 600 Printer Logo
Posted on Jul 05, 2011
I have a Cannon IR 550 and I get an error message E069 and I know how to fix it, well sometimes I get a message that says: Replace the cleaning belt, this belt where it is and how it changes? Thanks for the help
5 Related Answers
Anonymous
  • 163 Answers
  • Posted on May 08, 2007
SOURCE: Cannon Image Runner 330s
There is nothing wrong with the solenoid. The fuse cleaning web is similar to a roll of paper towels. For each copy made the copier fires the solenoid, advancing the web roll slightly. You can override the error but that will damage the upper fuser roller since it won't be cleaned and lubed properly. You need to replace (or have replaced) the cleaning web and reset the web counter in service mode. I am not sure on that model but when you purchase the web, $15-20, they can tell you how to reset it. Good Luck.
Anonymous
  • 20 Answers
  • Posted on Nov 28, 2008
SOURCE: Cannon IR 2200
OK i am having the same problem but here is the solution that I have found online that I am going to try in the next 5 minutes:
waste toner container is placed left-rear side of the machine. Take out one screw,small cover will come out then pull out plastic container. Empty the container and clean the head really well as this can cause problems with the fuser.
good luck!
Anonymous
  • Posted on Apr 20, 2009
SOURCE: cannon mp150 error 2 message what does this mean
error 2 probably means out of paper - thats what it means for my pixma mp140
Anonymous
  • 6 Answers
  • Posted on Jun 07, 2009
SOURCE: Cannon IR 3100 CN Itermediate Transfer Belt error code E00070-000
The E00070-000 is not a ITB problem, but a full wastetoner. Open the front cover find the white bottle in the middle, remove the black screw, remove the cover over the top of the bottle and empty the bottle. Be sure to clean the top of the bottle so the sensor can see that the bottle is empty. Restart the copier.
Anonymous
  • Posted on Aug 30, 2009
SOURCE: canon ir 7200 error code e069.
The large tr/sep charger on the bed has three pin style contacts at its rear. When you raise the bed the three contacts lift and make contact with leaf springs that press against the charger pins delivery charge to the coronas. These leaf springs become bent back and need to be bent to original position in a triangular configuration.
How can i resolve error cord No. E0000-0000 for cannon ir 2202
hi, you must replace fixing assembly, but first you have to enter in service mode to clear the error.
2answers
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
5helpful
2answers
My xerox machine cannon IR 2020 shows a system error E007. How can I solve it? Please describe step by step.
E007 - Fixing film rotation error
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says:
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
5helpful
3answers
Canon ir 7086 error code e00005-0010
give me the solusion of error code 225 of machine cannon 7086
reply plzzzzzzz
4helpful
4answers
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
8helpful
3answers
Canon ir 7200 error code e069. Replaced the chargers but the same thing persist.
13helpful
2answers
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS
7helpful
Message paper jam and open left drawer cover
Delay Jam in Delivery Assembly (Paper Leading Edge Jam at Delivery Sensor/Wound Paper Jam at Fixing
Assembly
3helpful
I recieved Code E069 in my machine
hi
error E069 is high voltage leakage?clean transfer unit and separation corona,
6helpful
4answers
About error code
cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
old marine
old marine
ZJ Limited
ZJ Limited
