RCA HD52W59 HDTV Projection Television Logo
Posted on Jul 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When you turn the tv on, nothing shows up on the screen, and it makes a whistling noise initially. my cousin thinks it could be the projector relay... what do you think?
Anonymous
Level 3:
  • RCA Master 5,138 Answers
  • Posted on Jul 06, 2011
Anonymous
RCA Master
Level 3:
Answers
5138
Questions
5
Helped
1003639
Points
13534
Problem will be on the Deflection Board, something is shorted in hori circuit.
PTS rebuilts boards 1-800-844-7871
Nothing showing on the wall screen from my projector
Generally a blown Lamp. If you see a start up screen when you first turn on the projector then it's a cable issue or you haven't initialized external screen.
1helpful
Infocus projector makes a whistling sound then shuts off
The whistling is nothing but noise. You need to open the projector to confirm the source of noise. It can either be mechanical or electronic. Possibility of mechanical noise sources are colour wheel (a 4 colour wheel near the lamp), blower fans & exhaust fans. All these are rotating things. If any one of them is jammed, then so as to try to rotate at full speed creates noise. To reduce mechanical noise it is necessary to service them. Dust is one of the main reason. For electronic noise check SMPS (Switched Mode Power Supply) & lamp ballast (electronic choke).The electronic noise is a high frequency noise generated by such devices. Are you using the projector in dusty envionment?
1helpful
Viewsonic Projector PJ506D not working
proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
the colorwheel is wearing out and need replacing.
Loud whistling noise coming from tv speakers
a couple of things could make the tv chassis whistle
1 coud be dry solder joint probably on power capacitors
2 IF your tv has tube the board on the back could be making the noise its to do with the yoke on the way out!
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
2answers
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
3answers
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
