Maytag Atlantis MAV6000 Top Load Washer Logo
Posted on Jul 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My maytag atlantis will fill but now wont run or drain. If it is the lid switch how do I fix it?
Mike
Level 3:
  • Master 4,383 Answers
  • Posted on Jul 06, 2011
Mike
Master
Level 3:
Answers
4383
Questions
Helped
1260230
Points
17064
If it is a lid switch, you replace it, however I suggest a continuity test with a Volt/Ohm meter. The switch needs to be able to open and close, electrically.
Maytag Atlantis MAV6451 - The machine buzzed and stopped. Now it wont run. Dont think its the lid switch
does it fill with water?
Does it not do anything after it fills?
If this is the case than it is most definitely the lid switch.
I recently had the exact same problem. Easy fix if you are handy.
Remove back of control panel to access the mounting screws. this will give you hand access to the lid switch. Try manually activating it after letting it fill. Replace switch or repair if able.
Good luck
1helpful
3answers
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
1helpful
Washer is filled with water,,it wont drain,,nor
Sounds like a bad lid switch. When you close the top lid, there is a safety switch that closes, it is actuated by a pin attached to the lid, there will be a small hole located on top of the machine, somewhere on the perimter of the top of the tub. Could also be a bad timer.
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Water will not drain, will not do anything.
I would check the lid switch. That is most likely the problem.
2helpful
Maytag Atlantis MAV6200 fills but doesn't do anything afterwards
If nothing turns on than your Lid Switch is probably it.It is the first most common fix on this model. Please Rate This !!!
Maytag atlantis washer
hi thanks for the question you say you activated the washer with screw driver . is the striker on the lid there ,.you could have a broken striker. check that if its there . replace the lid switch the appliance doc
1helpful
Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
Fills with water than nothing!
Most likely it's the lid switch, part number 22003804.
Remove the back of the console to gain access.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
