LG 42PC3DV 42 in. Plasma EDTV Logo
Posted on Aug 25, 2008
LG 42pc3dv-ud my tv screen just went totally blank, I can hear sound but there is no picture at all. is it going 2 cost more to fix it then to buy a new one? PLEASE! HELP
  • Anonymous Oct 27, 2008
    sAME PROBLEM ANY HELP OUT THERE EMAIL [email protected] THANKS.
  • SDavis0331 Oct 31, 2008
    I have the same problem! My husband and I were watching the TV- and then lost picture completely. We still have sound! "No signal" is bouncing across the screen.
    Please HELP!!!!
    email. [email protected]
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Aug 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2660
Points
20
Yes you need to replace the board LG 6871QYH048B. The board has a short. Check the fuses and one of them should have no continuity
because it is open.
Replace that board and problem solved
  • Anonymous Apr 30, 2012
    Is it easy to take out & put back a new one? Is it possible that I can do it myself?
2helpful
2answers
We have a Samsung PS50Q91HDX Plasma Tv which is not quite 3yrs old. Ever since we have had it, it turns itself on & off at random but this is not the main problem. Last night we were watching a show...
This is weird. I also have a plasma 50" model PS5Q91HDX and on the 5/02/11 the screen went blank when my friends daughter was watching a Wiggles DVD. The image kept coming back, flashing a scene or two before going black again. But the sound is perfect.
I wonder what is going on? Is anyone else having trouble with their 3-4 year old Samsung 50" TVs???
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
LG Plasma screen just went nuts
It could be any of 4 boards, either take it in for service or get a new set.
Blank screen on panasonic television
Hi, u have clearly mentioned that u are able to hear the sound from ur television. So the audio port of ur tv has no problem. The problem is that the picture tube of ur tv has damaged totally. Video output port has lost its ability to display on screen. If u are in a option of repairing ur tv its better to get a new picture tube or else if u opt for purchasing ur new television its well and good. but the cost for replacing ur new picture tube costs more.
1helpful
I have sound but no pic
replace display board.
if unit is under warenty
LG is very good at sending out replacment boards.
3answers
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
DELL 42 inch Plasma TV
I have a 42" LG LCD TV and just experienced this today. Watching cable, then the screen went to black, but audio continued. I pressed the guide button on my remote and pic came on with my guide menu. But then went to black again 10sec later and has remained that way for nearly an hour. Tried switching off both cable box and TV, disconnecting and reconnecting cables, but no luck. Finally unplugged mains, waited a minute, then turned back on. Everything seems normal now after the reboot. Phew.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
